Progress? Updates?
Can you ask greg for exact measurements? I'm considering having them made out off aluminum at this point...lol
Progress? Updates?
Welcome to the Jungle.
Any chance you'd offer a group buy. I'm looking to buy a set soon and I know one other person that would be in on it.
My build thread
-Matt
1988 Supra 2JZGTE Pwrd, Gt4294 Turbo, Drewgo Turbo Manifold, QSV, Tial 44mm wastegate, Max Autowerks Intercooler, Greddy Type R BOV, God Speed Intake Manifold, Weldon 2025 FP, Aeromotivo FPR, 780cc injectors, AEM EMS V2, GSC S2 cams & springs, th350 w/ 4000rpm stall.
Most likely no group by with this batch maybe the next go around. Greg should be getting the arms back any day now. He told me today that he will start machining the bushings next week for them. Greg isn't willing to give out measurements. I'm sure if you wanted solid bushings any machine shop should be able to take measurements from your arms and make some. Still probably a week to 2 weeks until new arms and bushings are available.
Traction Arm are back for sale! Will be Next Tuesday May 29th
FYI They are on sale!
Thanks for the update Jake!
Any bushings ready for purchase?![]()
New update on replacement bushings, Greg does not want to make a replacement poly bushing for the first gen rubber because the casting is to thin around where the bushing is. He said he has done it ounce or twice before and the customer was not happy at all with it, so he will no longer do it. It created chatter on hard launches instead of hooking up and grabbing like it should. The latest gen casting changed the amount of surface area around the poly bushing to eliminate as much of the chatter as possible. However the First gen arms can be replaced by a factory style bushing. I'm working on a part number now for it. But I would recommend sticking with rubber bushings in that gen arm or trying to sell those and getting the current model of traction arms with the poly bushings.
Ok, keep me posted on rubber.
Updates?![]()
Bookmarks
