This Is a Craigslist find I picked it up for $800 with no engine, wire harness, or ecu. I initially tried to get someone to buy it but no one wanted to. So I bought it even though I already had two at home(sisters). I really need to stay off cl! I have owned four supras in the last six years, and I'm hoping this will be my last. Time to do it right!
My last car was a 89 with a 1j. The engine craped out on my so I was left with a car with no engine and a great interior. So since I like the way the metro blue 87 looked on the outside but not the blue interior with the checkered seats. I decided to get the best of both worlds, and put the grey interior in my gay blue car. The colors go well together, I don't know why Toyota didn't do it. I guess the had a lot of ugly blue material to get rid of.
I plan on building the car up to 600hp in two steps. First is getting the engine in and running then stage two will be cams, fuel system, and stand alone. I also have a lot of parts that I need for my build from my 1j. That should make things easier for me.
Parts I have so far are. (Running total for those thinking about 2j swap)
$6934 including the car. The car was $800. Parts and supplies $6134
0. Car $800
1. 2jz engine (from jdmsource.com) $2135 shipped to me
2. Cobra rims (craigslist) $300
3. Brake master cylinder (Autozone) $55
4. Clutch master cylinder (Autozone) $45
5. Slave cylinder (Autozone) $30
6. Fidanza light weight fw. http://www.clutchflywheel.com/ $330
7. Act xtreme 6 puck sprung kit http://www.clutchflywheel.com/ $555
8. 6 injector and 6 coil pack clips http://www.bmotorsports.com/ $85
9. Bell housing. (Champion toyota supraforums) $300
10. Toyota gasket set. (Champion toyota supraforums) $390
11. Toyota water pump. (Champion toyota supraforums) $120
12. Toyota oil pump. (Champion toyota supraforums) $160
13. EBay log manifold. (Ebay) $170
14. 38mm to 44mm wg adapter. (ebay) $25
15. turbo down pipe kit (driftmotion.com) $135
16. 1jz flywheel bolts (driftmotion.com) $30
17. Gates Racing Timing Belt for 2JZ (driftmotion.com) $73
18. Marlin Crawler Shifter Socket R154 (driftmotion.com) $6
19. Shifter Bushing For R154 (driftmotion.com) $12
20. R154 Transmission Output Shaft Seal (driftmotion.com) $10
21. Redline MT90 Manual Transmission Fluid (driftmotion.com) $11
22. Split Loom 1.25 inch (driftmotion.com) $12
23. R154 Input Shaft Seal (driftmotion.com) $10
24. Aem Tru boost boost controller (Ebay) $255
25. r154 front bearing retainer (toyota oem parts world) $65
26. Crank position sensor (toyota oem parts world) $105
27. lo-tek 2 gauge pillar pod (gaugepods) $64
28. Timing belt tension (autozone). $45
29. Clutch Release Hub Kit R154. (DM) $25
30. R154 Factory Toyota Transmission Mount for MK3 Supra (DM) $69
31. Walbro Fuel Pump For 84-92 Supra (DM) $93
32. R154 Fork Support with Spring (DM) $47
33. Clutch fork (member) $40
34. Oval alt 3 pin connector (DM) $7
35. Denso Norrow Band o2 sensor screw type (DM) $53
36. 3 inch exhaust gasket (DM) $7
37. SS 3 inch exhaust flange (DM) $15
38. V-band 3 inch exhaust kit (DM) $30
39. 2jzgte valve cover ventalation hoses (DM) $17
40. Battery tie down (DM) $18
41. 12 mod supplies (radio shack) $45
42. Intercooler Supplies couplers, t clamps, (siliconeintakes.com) $90
43. Toyota Fuel filter (toyota dealer) $25
44. Toyota Oil filter (toyota dealer) $20
I tried selling it once but no takers ( I was kinda happy about that) this is her at home cleaned up.
I need to get pics of it with the grey interior..... But here are some of the engine that jdmsource sent me. actual pics of the engine they will be shipping.
Bookmarks
