+ Reply to Thread
Page 1 of 10 12345 ... LastLast
Results 1 to 10 of 93
Thread: New product available. Adjustable rear control arms.
  1. #1
    Beech Performance Motorsports
    wesbeech's Avatar
    Join Date
    Feb 2006
    Location
    Akron Ohio
    Posts
    1,019
    Default New product available. Adjustable rear control arms.
    Custom made tubular rear control arms for the mx83 Cressida. Also available for the mk3 supra.
    These custom made arms are fully adjustable. They use heavy duty heim joints rated for 22,000 pound of force. The tube is heavy duty DOM steel tube. The u bent brackets are made out of 3/16” steel. We use custom made and machined parts meant specifically for these arms. No parts are modified or adapted to be used. All the parts are made for one thing and one only these control arms. We do not use reducer bushing like other company have to try to cut down on cost. These are fully TIG welded by an aircraft and top fuel bike fabricator. We also have rosette welded the ends for extra strength and safety. These are a must for lowered or track cars. No matter how much you lower the car or what you do. With the adjustably of these you will be able to get your car back into spec. They are much stronger and beefier than factory they will not fail like others do.
    The price is $200.00 for each one plus shipping.
    1. Control arm
    2. Toe arm
    3. Traction arm
    Thanks for stopping by and checking out the new product.
    Here are the pictures of the arms. The Cressida arms are pictured. I will get pictures of the supra one soon they are very similar
  2. #2
    Offical SM Expert: Suspension & Vehicle Dynamics
    supraguru05's Avatar
    Join Date
    Dec 2005
    Location
    louisville ky
    Posts
    717
    Default Re: New product available. Adjustable rear control arms.
    I was wondering when you were going to list these for sale. Could you please tell me the shortest and longest length as well as the thread pitch for the camber link.
    1989 toyota supra white package DD
    1989 toyota supra NASA TTC track car
    thanks to
    Supramania.com, No Lift Racing, Epic Motorsports
    Visit My Sponsors At
    NOLIFTRACING.com, brewerheatingandair.com
  3. #3
    Authorized Vendor
    empera's Avatar
    Join Date
    Mar 2005
    Location
    Philly.
    Posts
    4,947
    Gamer IDs
    PSN ID: empera
    damn wes they look great....hopefully i'll be able to grab a set in the near future.
  4. #4
    IJ.'s Avatar
    Join Date
    Mar 2005
    Location
    Posts
    38,654
    Would it be possible to offer Poly Rod ends as an option for the purely street Supras?
    (quieter and better longevity in a DD car)
  5. #5
    wesbeech's Avatar
    Join Date
    Feb 2006
    Location
    Akron Ohio
    Posts
    1,019
    Quote Originally Posted by supraguru05 View Post
    From stock you have + and - about a 1/4" each way on all e arms and the front toe arm has an extra + and - 1/4" cause it has 2 heim joints. The big joints are 16 TPI and the small ones are 18 TPI
    Quote Originally Posted by IJ. View Post
    Maybe when i get some time ill look into them to see how much redesign will be needed. Im sure it will cost a bit more but ill look int it.
  6. #6
    shaeff is FTMFW!
    supra90turbo's Avatar
    Join Date
    Mar 2005
    Location
    MA, 01440
    Posts
    6,194
    Gamer IDs
    Gamertag: supra90turbo
    That would be well worth the extra money for the poly rod ends! Good find, Ian!
    Damn... If I didn't have the A-1 arms already....
    Tired of having multiple keys? PM me for re-keying lock cyls
    ------3E5 1990 Turbo Targa - 206 1990 Turbo HT-------
  7. #7
    IJ.'s Avatar
    Join Date
    Mar 2005
    Location
    Posts
    38,654
    Yep used Heim joints in road cars in the past and HATED them and that was in noisy rattly cars to begin with not Smooth Quiet LuxoBarges like a Mk3
  8. #8
    Join Date
    Dec 2005
    Location
    louisville ky
    Posts
    717
    Quote Originally Posted by supra90turbo View Post
    sell them and buy these. In all seriousness the A1 arms are swedged steel which is prone to cracking. These arms are the simplest replacement arms. Only issue is since its a larger diameter tube on the traction arm tire clearance could be an issue for some people.
    thanks to
  9. #9
    shaeff is FTMFW!
    Join Date
    Mar 2005
    Location
    MA, 01440
    Posts
    6,194
    Gamer IDs
    Better made, made by a supramania member, cheaper, hmm...
    Anyone want a set of A1 arms? I'll trade straight up for these
    Are these powdercoated or painted? Do we have a choice of color?
  10. #10
    wesbeech's Avatar
    Join Date
    Feb 2006
    Location
    Akron Ohio
    Posts
    1,019
    Powder coated. They come blue but for the extra cost of the powder i could do a diffrent color.
    ---------- Post added at 02:31 PM ---------- Previous post was at 02:30 PM ----------
    They are 1 1/4" od so they are not a ton bigger
+ Reply to Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Links monetized by VigLink
