+ Reply to Thread
Results 1 to 8 of 8
Thread: Wastegate sizing...
  1. #1
    Junior Member
    nsngarage's Avatar
    Join Date
    Jan 2009
    Location
    Pittsburgh, PA
    Posts
    111
    Points
    560.3
    Level
    8
    Lv. Percent
    45.17%
    Weekly Activity
    418.15%
    Default Wastegate sizing...
    Is there a certain way to figure out what size wastegate you would want on your car?... I know it is different with different turbos and such... but is there a general "guide" to sizing them?
    I know how they work and all, just dont really understand how to match them up with a turbo..
    I've searched the forums and can't find the actual answer im looking for lol...
    If anyone is well versed please teach me! :-P
    thanks!
  2. #2
    Get the gate!
    pln's Avatar
    Join Date
    Apr 2007
    Location
    eskilstuna.SWEDEN
    Posts
    107
    Points
    336.8
    Level
    Lv. Percent
    70.96%
    Weekly Activity
    124.26%
    Default Re: Wastegate sizing...
    I havnt seen any certain way to calculate this, only roughly what determins wastegate size. Differences between compressor and turbine, like if you have compressor thats big in relation to turbine you will faster build more pressure in exhausts. Exhaust house design on turbo matters.. small a/r will build upp more pressure and need bigger w-gate to evacuate gases. But all this is very depending on what boostlevel you are planning. More boost=more exhaust gases.
    This is just my conclusions. Im no expert so everyone else feel free to fill in. I could see my boost taking off at 6000rpm with gt35 1.3bar(not sure of a/r),, and it could be other things that caused the problem but i decided to play it safe and go for 50mm w-gate.
    If you are uncertain... just go for the bigger w-gate.
  3. #3
    IJ.'s Avatar
    Join Date
    Mar 2005
    Location
    Posts
    36,890
    Points
    82559.4
    Level
    68
    Lv. Percent
    80.99%
    Weekly Activity
    22845.61%
    The bigger the AR on the turbine the less gate size is needed
    Opposite if you're trying to run low boost on a bit turbo with a normal AR.
  4. #4
    MKIII owner.
    foreverpsycotic's Avatar
    Join Date
    Jul 2006
    Location
    Norwalk, CT
    Posts
    3,072
    Points
    10772.7
    Level
    30
    Lv. Percent
    77.71%
    Weekly Activity
    213.54%
    Is there a point that is too big, and will hinder performance?
    There's something about cruising the streets in a highly modified 20+ year old Japanese car, and absolutely raping the newer domestics/imports that I just couldn't replace with a newer car... Click here to enlarge - shaeff
    Build Thread > http://www.supramania.com/forums/showthread.php?t=44235 < Updated: 03/04/10
  5. #5
    member
    X-man's Avatar
    Join Date
    Dec 2005
    Location
    Pulaski,Va
    Posts
    301
    Points
    656.9
    Level
    9
    Lv. Percent
    8.66%
    Weekly Activity
    90.77%
    I run a 44 mm Tial gate with my GT42 with a 1.01 a/r on the turbine side, I ran a 40 mm HKS gate on my 67 mm turbo with both a .68 and a .81 a/r turbine housing and a p trim wheel. I have run boost levels on both set ups as low as 13 psi to as high as 30 psi with no creep or control issues. There is a 15 psi spring in the Tial gate and was a 10 to 11 psi spring in the HKS gate.
    As a side note I run a 60 mm gate on our turbocharged S10 with a 383 CID and an 80 mm turbo with a 1.30 a/r on the turbine side with a 96 mm wheel and have run as low as 6 psi on it to as high as 18 psi.
    88 turbo GT42
    753 rwhp/ 589 rwtq @ 30 psi on stock internals
    www.boostwerx.com
    http://www.coltranewelding.com/dyno.htm
  6. #6
    Ported & Polished
    Nick 95 6sp's Avatar
    Join Date
    Sep 2007
    Location
    S.E. PA
    Posts
    116
    Points
    372.1
    Level
    7
    Lv. Percent
    4.05%
    Weekly Activity
    280.51%
    Click here to enlarge Originally Posted by foreverpsycotic Click here to enlarge
    as a "data point" that might reflect a larger than usual wastegate with a smallish turbo, my PHR Stg1 turbo, which is a 60-1, on my modified Turbonetics cast manifold, uses the HKS 60mm GT wastegate. It controls boost perfectly anywhere from wastegate spring boost of 17 psi to over 30 psi.
    I think the type of boost controller also plays a role...what I mean is that some boost controllers can pulse the signal to the wastegate which helps in controlling it to what amounts to modulated flow rather than just open and closed. I think my Blitz SBC-iD which has two quick acting solenoids helps control boost better than some other ebc's for that reason.
  7. #7
    Got a bad habit
    leecheater's Avatar
    Join Date
    Mar 2006
    Location
    St. Cloud, MN
    Posts
    231
    Points
    825.2
    Level
    10
    Lv. Percent
    5.71%
    Weekly Activity
    725.07%
  8. #8
    Junior Member
    nsngarage's Avatar
    Join Date
    Jan 2009
    Location
    Pittsburgh, PA
    Posts
    111
    Points
    560.3
    Level
    8
    Lv. Percent
    45.17%
    Weekly Activity
    418.15%
    good info, i kinda knew about the a/r being bigger means less of a wg.. Just wasn't sure exactly how to calculate it all... But appreciate all the info! I'm going to do some more research on the spring parts and all just to know that I know what im doing lol...
+ Reply to Thread
Similar Threads
  1. Wastegate sizing
    By bosco659 in forum 7M-GTE Engine Technical Discussion
    Last Post: June 1st, 2009, 12:37 AM
  2. Question About rim sizing
    By senseikrang1 in forum General MKIII Discussion
    Last Post: September 12th, 2008, 11:50 AM
  3. wastegate sizing questions
    By tweak666 in forum 7M-GTE Engine Technical Discussion
    Last Post: February 4th, 2007, 03:59 PM
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
