+ Reply to Thread
Results 1 to 2 of 2
Thread: Boost Cut Controller (BCC) 2jzgte vvti & Speed Cut?
  1. #1
    Lurker
    Turbo819's Avatar
    Join Date
    Jul 2008
    Location
    NYC
    Posts
    Points
    80.9
    Level
    Lv. Percent
    2.25%
    Weekly Activity
    62.87%
    Default Boost Cut Controller (BCC) 2jzgte vvti & Speed Cut?
    First off Thanks for any helpful information on this subject
    Second I know a few would say use the SEARCH button it very useful. I have. I did a 2jzgte vvti swap a year ago. Now I am in the process of going single
    What I am using
    Factory ECU
    440's Injectors (I can use 550's if I can source a set before I go to the Tuner)
    Garrett GT3582R .82
    AEM FIC
    W58 Transmission
    That why I might use the 440's or if I use the 550's power would be kept to way under 450rwhp
    The Question:
    For those the 2jzgte vvti and decided to up the BOOST. What was used for the boost cut? Boost Cut Controller (BCC)
    What was used for the Speed Cut?
  2. #2
    Lurker
    dmd0652's Avatar
    Join Date
    Jun 2009
    Location
    NH
    Posts
    Points
    72.4
    Level
    Lv. Percent
    87.33%
    Weekly Activity
    62.87%
    Default Re: Boost Cut Controller (BCC) 2jzgte vvti & Speed Cut?
    http://www.mkiv.com/techarticles/bcc...GReddy_BCC.htm
    That should answer any questions you may have regarding boost cut. As for Speed Cut, can't say I've heard of such a thing. If you're referring to overall top speed, I'd guess your foot would be the way to go. Then again can't say I've heard of anyone wanting to limit their speed. Click here to enlarge Good luck.
+ Reply to Thread
Similar Threads
  1. Manual Boost Controller, Boost Gauge & BOV ?
    By 88-1J in forum Other Engine Tech (1JZ-GTE, 2JZ-GTE, Etc)
    Last Post: October 21st, 2007, 03:44 PM
  2. 2JZGTE VVTI from Aristo work in MKIII 5spd?
    By tremendo_leo in forum Other Engine Tech (1JZ-GTE, 2JZ-GTE, Etc)
    Last Post: February 7th, 2007, 12:05 PM
Visitors found this page by searching for:
BOOST CUT 2JZGTE
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
