is this helical differential any good? http://cgi.ebay.com/ebaymotors/OBX-L...#ht_2567wt_939
i heard obx is not the greatest either.
my car vibrates at over 75mph im not sure what it is lol
hey guys after i read some of the post, just wonder how to see if there is play on the rear end? like spinning the shaft? i put my car up today to see whats up with my DS cause i got some vibration and low speeds and then over 80-90mph will get very bad, i did spin the drive shaft and ill give it about half inch moved and the wheels didnt spin, and when i also engage my clutch i hear some banging sounds like if my ds is trying to catch or something, im kinda starting to think its my rear end.
94 tercel jdm starlet 4efte swap, act stage 2 clutch, 13lbs of boost - sold
93 delsol z6 turbo, eagle rods, vitara pistons, 57 trim turbo garret, 21psi - back to friends house
88 supra 7mgte, rebuilding in process
I am wondering if that isn't from the u-joints. I have had u-joints cause vibration on my GM vehicles and changed them out myself. Have avoided looking at the Supra system simply because they are more complex than the simple ones found on other cars.
(not sure if I am correct on this, but I thought there were more u-joints on a Supra)
well came to find out my bolts on the shaft were coming loose, just happened out of no where
i have an aluminum one piece, and it gives me the same problem... Ive flopped the drive shaft both ways and get the same result... got any ideas guys?
Um, driveshafts are not 'floppable'... I'd go to a driveline specialty shop and have it checked for straightness and if it passes have it balanced.
-Steve
91 Supra- built 7M, Billet 67, couple other fun bits!
Best dyno: 564hp, 479tq @ 26psi on E-85.
Best 1/4 mile: 11.83 @ 118
My build thread: The Toyotanos Build!
Seems my pic doesn't work so I'll post it here again..
Bookmarks
