WTH: Plastic rear end link??
sinistar_xx
Authorized Seller
Joined
Dec 28, 2018
Messages
140
Was doing the rear pads and rotors on my '89 today and noticed what looked like a PLASTIC end link. I wiped away some grease, and yes it was in fact plastic. I would never expect to see any component like that made of plastic. Checked the other side and it's the same. This is not normal, correct? Anyone else seen this before? Either way, they're due for replacements...
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
2,234
Location
MKE, WI
Yeah those are not that uncommon to find.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,234
Location
MKE, WI
They are factory but I don't recall offhand what the PN# is.
sinistar_xx
Authorized Seller
Joined
Dec 28, 2018
Messages
140
That's very interesting. Thanks for the feeback, guys.
P/N is 48830-14040 FYI.
plaaya69
86.5 Turbo Converted Supra
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,560
Location
Lake County, IL
The 89+ changed to plastic sway bar end links. The older mk3 Supra's were metal links which I heard had problems with bending but I don't hear much about that. They also make upgraded links that are adjustable if you are looking around for different options and these are the ones I run:
  • Like
Reactions: sinistar_xx
Enraged
A HG job took HOW long??
Authorized Seller
Contributor
Joined
Messages
2,098
Location
Victoria, BC, Canada
I think it was more of a problem with the mounting tabs on the lower arm breaking off. So hopefully the plastic fails first. I know some people have had that lower tab break off when upgrading to bigger sway bars and endlinks.
