Working on a new clutch option for r154
Zazzn
OLD school
Authorized Seller
Joined
Messages
1,138
Location
Toronto / San Francisco
Hi All,
Just wanted to poll what’s left of the mk3 community.
I’m working on creating a few new products. One of them is a twin disk r154 clutch with a good movement alteration kit which is not a pos like the spec clutch. I’m aiming for the clutch to be about the price of a premium single single disk option when you purchase a flywheel. Price range a good 300-400 than the next alternative. By having a twin disc we won’t need super heavy pressure plates and the whole assembly comes with a flywheel as well as most twins do. Meaning this would be cheaper than a single ACT or Southbend.
I expect the clutch to hold more than wheel tq than an r154 is good for. Just initial interest as my R&D samples are being made.
I’m going to seek approval for a group buy eventually
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
2,363
Location
MKE, WI
I may be interested depending on additional details / specs.
Are you working with clutch masters?
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,363
Location
MKE, WI
Also this is going to be mated to a steel flywheel correct?
Enraged
A HG job took HOW long??
Authorized Seller
Contributor
Joined
Messages
2,114
Location
Victoria, BC, Canada
I love the idea, but my clutch is pretty new so I wouldn't need one anytime soon.
Would it be like a Clutchmaster or Quartermaster setup? It would be nice to be able to use standard stocked parts if you have to rebuild it vs totally custom.
GC89
BoostRodeo
Authorized Seller
Contributor
Joined
Jun 13, 2007
Messages
1,047
Location
Spokane, WA
7M, JZ or both? I have been dragging my heals on ordering a OS Giken tripple or quad as my current twin is not too happy. Would consider this depending on price and tq rating. Are you planning on a movement alteration kit or a hydraulic release bearing?
suprarx7nut
YotaMD.com author
Authorized Seller
Joined
Nov 10, 2006
Messages
4,176
Location
Arizona
I'm in the market for a quiet and stock-like twin disc for my R154. My main criteria is smooth engagement and minimal or no rattling with clutch pedal depressed. Most the twin discs I've heard have sounded awful in parking lots. That sort of noise and chatter would be a complete non-starter for me.
Zazzn
OLD school
Authorized Seller
Joined
Messages
1,138
Location
Well, I can see people are looking for all their preferences.
I'm going to say there are a billion options already available, what I'm trying to do is bring a twin / triple to the market at the price just above a single setup. It's going to use a chrome-moly flywheel multi discs are always going to make noise, i'll have to see how much when my samples arrive. Weight will be similar to OS giken with a chrome moly flywheel, billet cover. Realistically, if you care about weight Tilton quartermasters are probably what you want.
Also not working with clutch masters.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,363
Location
MKE, WI
As GC89 asked, what engine are you making this to?
Staying tuned to hear what the results are.
GC89
BoostRodeo
Authorized Seller
Contributor
Joined
Jun 13, 2007
Messages
1,047
Location
Spokane, WA
Some are better or worse but I have personally never seen a multi plate clutch that did not make noise. Even basket design single discs exhibit this, its just part of the design and the cost of obtaining more grip without absorbent pressure plate tension rates.
Enraged
Authorized Seller
Contributor
Joined
Messages
2,114
Location
Will it be a full flywheel? Or a button flywheel that you use with a flex plate for the starter ring gear?
suprarx7nut
YotaMD.com author
Authorized Seller
Joined
Nov 10, 2006
Messages
4,176
Location
Arizona
I seem to get varying answers from people on this. Some say a properly tensioned ,ulti-disc assembly will have very minimal chatter. Others, (like here) say it's always noisy as shit and that's life.
I don't see why the rattling clatter is necessary, but I guess I don't know exactly how that assembly behaves in motion. I'll keep dreaming about a quiet and respectable multi-disc clutch though, dammit! Haha.
GC89
BoostRodeo
Authorized Seller
Contributor
Joined
Jun 13, 2007
Messages
1,047
Location
Spokane, WA
Without chatter, definitely achievable, essentially silent like a sprung single disc, I don't think it is possible. To me when someone talks about chatter they are referring to engagement not noise. A multidisk can be very smooth depending on disk materials and the movement design of the clutch.
The issue with noise is you have significantly more parts in a multidisk. In a single disk you have a fly wheel which is fixed, a pressure plate which is fixed to the flywheel and the disk in between. Even when the clutch is pressed and unloaded the disk is contacting both surfaces, even if it weren't and it were able to vibrate freely the friction materials would be what is contacting the flywheel and pressure plate surfaces.
In a multidisk you have the flywheel and pressure plate fixed together still but connected by the basket rather than directly bolted together. The friction disks commonly are separate from the hub that slides on to the input shaft. This is one point of free movement when unloaded. Then you have a steel friction plate between each pair of disks which is also hubbed and locked in by the basket. Theses are two more points of intermittent contact when unloaded. All these parts vibrate when the clutch is pressed and everything is unloaded, its just the nature of the design. Some are noisier some are less noticeable but I have yet to work with one that doesn't suffer from this.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,363
Location
MKE, WI
2 of the key components to reduce chatter on twin plate clutches.
-Marcel Plates
-Orgainic full faced clutches
Especially without Marcel Plates, expect chatter and poor drive-ability on the street.
Moving toward pucked clutches or non full faced clutch designs will also increase chatter.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,363
Location
MKE, WI
Is the product done being designed yet?
Koenigturbo
Well-Known Member
Authorized Seller
Joined
Oct 4, 2006
Messages
1,529
Location
Oxnard CA
I'm happy with my Center Force Clutch, the faster the engine runs the harder the clutch grabs
Zazzn
OLD school
Authorized Seller
Joined
Messages
1,138
Location
I have a sample but I haven't had time to get it in my car. Are you planning on getting your car up and going any time soon? We can work something out if you want to sample it. The V160 sample I have testing right now seems fantastic.
GC89
BoostRodeo
Authorized Seller
Contributor
Joined
Jun 13, 2007
Messages
1,047
Location
Spokane, WA
I needed a clutch swap last winter and just turned the boost down all year to get by. Whats the tq rating on it? Was planning on pulling the trigger on a OS Giken as soon as I get my tax return but you have my attention on this one. FYI my car runs and gets driven a lot!
