Vacuum lines
flubyux2
Madd Tyte JDM yo ®
Authorized Seller
Joined
Apr 2, 2005
Messages
1,019
Likes
Location
st. pete, fl
#2
the rusty nipples are coolant lines. leave those open.
there is another nipple under the #1 and #2 runners and a nipple on the metal coolant pipe under the rear runners, join those 2 nipples together w/ a 3/8" fuel hose and clamps.
this will keep coolant from circulating in your ISC and TB and keep it cooler when driving. wards off heat soakery.
madseacow
Authorized Seller
Joined
Apr 2, 2005
Messages
360
Likes
Location
Buda, Tx
#3
so your saying the ISC is left open and run the lines from the head back into itself. but what about the throttle body?
MKIIINA
Destroyer of Turbos
Authorized Seller
Contributor
Joined
Messages
1,825
Likes
Location
Plano, TX
#4
by-pass those lines as its to heat the throttle body up to help keep it from freezing (iirc) and simple heats up the intake air. just by pass the lines
Idealsupra
Authorized Seller
Contributor
Joined
Messages
2,390
Likes
Location
Orlando
#6
speaking of which...my bypass line is leaking...bastard ;)
ill have to pull off the hose when i get around to changing out the coolant ....
