vaccum for boost gauge
lifted
Authorized Seller
Joined
Jun 13, 2006
Messages
182
Location
memphis
2jz-gte vvti swap into 92 mk3 supra. just trying to make sure i got some vacuum pieces correct.
the vaccum line coming from the boost gauge pressure senor on the driver side shock tower goes to a t that i assume is the feed as its not connected, and then goes to the heater core.
is this correct? where should i connect it to in the 2j for vaccum?
also can the pressure tank be left off?
80sSupraPowa
Authorized Seller
Joined
Mar 13, 2006
Messages
12
Location
San Diego, CA
I switched to a single turbo so used the port highlighted in yellow for gauge, coolant valve, and bov. I'm not sure I like all the tees I had to add using the one port so maybe there is a more optimal configuration.
Is the pressure tank you are referring to circled in red? I was wondering if there was any benefit in reinstalling but believe it is only needed for the sequential turbo configuration.
lifted
Authorized Seller
Joined
Jun 13, 2006
Messages
182
Location
memphis
yes thats the one, i am stock twins. so i have to have it? it has a plug on it that i dont have a connector for on my harness.
