The Kamikaizen Great Unpoochening
Kamikaizen
Authorized Seller
Joined
Mar 17, 2018
Messages
Location
Longmont, CO
It's been a fairly long while since I introduced myself and my $1100 basket case. In that time I have been waging war against Previous Owner Repairs™and have finally come close to having an MA70 that's willing to be a car on a consistent basis.
So, onward with The Saga So Far:
There she is in all her 30 years old glory. By some miracle the car was, aside from the rims and a crappily welded in cat, 100% bone stock. Forgive the stupid Dutch angle, I was exhausted at the time and I'm no photographer. :p
Turbo, slushbox, targa, and no ABS. This was the exact format I wanted aside from the gearbox, but that's an easy fix for the future. The exterior trim is a bit schizophrenic, yet it still had the lower front lip. However, the reasons it was $1100: The transmission hemorrhaged ATF to the tune of it being undriveable without going Mad Max with a barrel of ATF in the back and a hose going straight to the dipstick tube to keep it fed. It also had a ragingly persistent misfire at about 3400 at anything aside from WOT, and it had the customary valve cover and CPS o-ring leaks to ensure the front subframe was well lubricated. Also cruise control as well as overdrive didn't work, because there just weren't enough presenting issues.
So first order of business was the transmission. Right away after dropping it the first problem was obvious; whoever installed it didn't fully seat the torque converter, munging its snout as well as the oil pump. So I had the torque converter rebuilt, hunted down a fresh oil pump and hauled all of it over to my driveline shop for a much needed rebuild. In the meantime I went through the EWD to figure out the cruise control issue, since that is a feature I do want to retain. And luckily it turned out to be pretty easy: The trans isn't original to the car, as evidenced both by junkyard grease pen and the fact that the speed sender in the tail housing was the ABS 20 tooth square wave variety, whereas mine needed the sine wave speed sender. After sourcing the right one and slapping that in along with the fresh box and managed to get back that badly needed 4th gear. My trans shop even reflattened the oil pan's mating surface so an actual gasket works instead of needing RTV. Hasn't leaked a drop since.
What decided to evade my efforts to suss out was that misfire. One of the coil packs was basically close to dead, which surely wasn't helping matters. And seeing the cost of a 7M-GTE coilpack I opted to go IS300 coils for basically the same price as just on stock coil. Along the way I also found someone had injectors 4 and 5 backwards. But still the misfire persisted. I had the ECU rebuilt by lscowboyls on Facebook, since my policy on a used car is Trust Nothing. But that didn't fix the misfire, though I didn't really expect it to. The igniter seemed fine so I left that alone...mostly because the only new/remanned replacement I could find was $800 through NAPA. Eventually my sights landed on the CPS, which had an absolutely horrifying splice job done on its wiring instead of just fixing the plugs like a normal human being:
So after seeing this I figured the whole CPS itself was suspect, and thus I threw it at my cheap oscilloscope and was greeted by a lovely, enormously lopsided waveform, in addition to it being about half the strength it ought to. Bullets were bitten and triggers were pulled on a remanned CPS, and after spending that much I figured another $5 on Driftmotion's CPS magnet wouldn't hurt any further. Slapping all that together I found a much more agreeable waveform, and after installation along with splicing in a new receptacle on the harness I finally fixed the misifre!
Happy boosting ensued. lol yarite. Instead I was greeting with all of 4PSI, but at least the damned thing was driveable...until the very day I took it for emissions and then the fuel pump decided at that moment it was ready for retirement. On the damned rollers. A bit of coaxing managed to get it to live long enough to pass, and then I immediately needed a tow back home. Which is the point I've been at since.
Current plans for the current issue are to get a mk4 TT fuel pump, a replacement gas tank because this one has a corner caved in, and because I am paranoid to no end I will be resealing the tank before it goes in. As well I'll be putting in a healthier CT26 and the fleabay CXracing elbow; which I had the gasket surfaced machined flat already. The compressor wheel on the current turbo is chipped more badly than a bag of Doritos and has enough shaft play it could sign on at a porn studio.
This 'build' thread isn't going to be terribly exciting for a long while to come, but it's been a wild enough adventure I figure it's worth documenting at least
  • Like
Reactions: YotedmyMA70
plaaya69
86.5 Turbo Converted Supra
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,572
Location
Lake County, IL
Glad to hear you are getting it up and running. You might want to go with a open mouth 1 piece downpipe like this style:
https://www.ebay.com/itm/86-92-Toyota-MK3-Supra-7MGTE-3-SS-Stainless-Steel-Turbo-Back-Downpipe-With-Flex/161672319550?hash=item25a46bd23e:g:LN0AAOSwcwhVLIs-:rk:27:pf:0
instead of just a turbo elbow because you will notice way more pickup and a better exhaust/turbo sound (I have owned both in the past on the factory ct26). One of my favorite mods on my factory ct26 turbo was shimming the wastegate for a tab bit more power but I would only do that once you know the motor/turbo is healthy and running good.
3p141592654
90T
Authorized Seller
Contributor
Joined
Oct 11, 2005
Messages
4,200
Location
Thousand Oaks, CA
Nice riead, I enjoy your writing style. Most likely your BOV (if it is stock ) is open all the time. This is a common failure and will do wonders for keeping your boost low.
  • Like
Reactions: debrucer
suprarx7nut
YotaMD.com author
Authorized Seller
Joined
Nov 10, 2006
Messages
4,169
Location
Arizona
Funny read. sounds like an adventure! I'm very near Longmont in case you need anything I can help out with, though it sounds like you're well on your way.
Good luck!
Kamikaizen
Authorized Seller
Joined
Mar 17, 2018
Messages
Location
Longmont, CO
Surprisingly the stock BOV works! At the least it doesn't appear to be leaking when I tested it anyway, but I might just give myself some peace of mind and throw a Bosch recirculated valve on there in the near future. One small correction I did do is replace the check valve for the IAC. For reasons utterly beyond my comprehension that was removed at some point in the past. My eventual plans will be a full exhaust with a real downpipe instead of this autoerotic asphyxiation tube Toyota bequeathed this thing at birth, but that involves funds I won't have for a while to come. So this will be an incremental improvement.
And today also revealed something that now amazes me the turbo still worked at all:
Whoever monkeyed with the turbo last thought that using the stock gaskets were a good idea. So a GREAT idea is to RTV them in place! Right? ...right?? *headdesk* Farging icehole choked off the oil feed to a third of what it should be and I'm lucky a chunk didn't get swallowed...at least I hope there wasn't. At least they were consistent enough to do the exact same on the block side, so I got that going for me.
So on the docket now comes a softline kit because fffff, I knew the stock pipe was a bitch but mein gott that was more hassle than I wanted. Along the way I also discovered that the wires to one of the aircon pressure switches that run along here had its wires snapped off. And considering me and warm temperatures are not on speaking terms I would really rather have working a/c this summer, thus moar parts get thrown on the list for this beast hungers.
@suprarx7nut Thanks! I've actually been watching your Youtube videos. They've been quite helpful!
supraguy@aol
Authorized Seller
Joined
Dec 30, 2005
Messages
4,247
Location
Atlanta
Nice work so far. And I appreciate the Johnny dangerously and Caddyshack references in your writing prose.
Hopefully, the farging bastage that owned your car before you, didn’t lay any additional traps along your path to automotive nirvana.
Kamikaizen
Authorized Seller
Joined
Mar 17, 2018
Messages
Location
Longmont, CO
OKay so, fair bit of time passed and not much of an update. But, after I yanked the turbo previously I found the wires to one of my aircon switches was snapped off at the top of what looked like the switch body. Luckily both are still available from Toyota so I snagged fresh units, because why not? This is the best time to tackle them!
First up, wires were snapped at the very top of that dust boot, leaving basically nothing to work with. So after a tough time digging out those bastardly copper spade connectors and watching them ablate at every touch I crimped some new ones onto fresh copper and put them back in their rightful place. This time I put a little extra wire length under the boot as shown so there's a little bit of flexibility.
Then once the connectors was soldered in place - don't worry, I used a 5% silver solder that is vibration tolerant so I don't expect those to break any time soon - it was time to put them back into their rightful place in the engine bay. A quick splash of R-12 refrigerant oil on the o-rings and we're back in business...almost. The system still doesn't hold vacuum so eventually I'll muck about replacing the remaining o-rings and receiver/dryer, but today is not that day.
The turbo side of things is pending acquisition of an oil soft line kit. Still making a decision on which one to pull the trigger, but hopefully it won't be too much longer until our regularly scheduled happy boosting recommences.
plaaya69
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,572
Location
Lake County, IL
Those new switches look nice. Do you plan on recharging the a/c with r12? I see some locally for sale and I remember the r12 freon worked so much better in my old 87 non turbo then when it was converted to r134a.
Kamikaizen
Authorized Seller
Joined
Mar 17, 2018
Messages
Location
Longmont, CO
Well...less of an update than I wanted, and far later than I'd've preferred. Long story short: I buggered the crap out of my wrist somehow, ECU tendon slipped free and I had to be put in a cast for a month, and now I am in physical therapy trying to get my range of movement back. It's been an utter hell, but recently I've been able to (carefully) do some more work on the two ton terrible terror.
First thing's first: Coolant sensors? All...five of the suckers got the out-with-the-old treatment. Why? Because these things were built when there was still a space shuttle Challenger, that's why. Plus the corrosion on the originals was an unholy sight:
And so with that out of the way - and undoing a previous owner's RTV job on the thermostat housing - I moved on to address the turbo problem. As mentioned before the compressor wheel is cracked something fierce and I want nothing to do with taking a risk of it grenading and worsening an already tired 7M. And so I had one sitting around I got from a Craigslist partout. The wheels are beautiful, shaft play is virtually nonexistent, so I'mma ship it.
Slight problem though: The water pipe's flange doesn't sit flush on this turbo for some reason. Both surfaces look decently flat. But I took some time to wire wheel them both in case there was any leftover gasket crap in the way. Which there was! ...the removal of which also changed nothing. So, slightly against my preferred desires I went ahead and put the water lines of my Mambatek hose kit on as well as the oil lines. Say what you will about not shopping at a tried and true brand name, but for the price this kit does seem to be fairly well made.
So, this is where I annoy everyone with pictures of Taiwanese hardware :>
Block side oil drain fitting: Pretty thick aluminum and the surface was nice and flat
Turbo-side oil fittings and hoses. The drain is a rubber hose while the pressure line is braided stainless. And yes, the observant may notice a constant tension hose clamp. I'm taking no chances, and these are cheap insurance so why not?
And here's a view of the drain hose and its route to the block side barb. I managed to get the barb at an angle to where it isn't right up against the turbo hot side flange, nor over so far as to have a level spot in the routing. The supplied hose was double the length needed, so there's enough to test fitment with.
A view of the pressure line banjo. The pressure line was pretty long so I routed it underneath everything and ran it behind the oil filter mount, which worked out nicely:
And you'll notice I reused the original banjo because... *drumroll*:
The channels on the supplied banjo bolt are just a wee bit smaller. So, I went with the OEM one to avoid any possibility of failing to deliver enough oil to the CHRA.
Now, the fact of a rubber drain hose bothered me a bit. Namely because of heat and how much exhaust side stuff it'll be very near to. So to ice this cake I got me some Thermotec velcro'd heat wrap and loosely wrapped the whole section. Seriously, I love Cheap Insurance improvements. The little stuff that provides purified peace of mind but also isn't just going open-door-insert-monies:
So...not glamorous, but it's been needing to be done. And with that I moved on to other issues. The next one being the left brake lights; tail light circuit works just fine. But hit the brakes and one bulb shuts off entirely and the other will either go full bore, or just run the brake filament by itself. After making sure there were no issues upstream - even the fail box has successfully failed to fail! - it had to be the bulb holder itself. Thankfully it ultimately came down to corroded ground terminals. A little wire wheeling and we were back in action.
...except the bloody fuel pump.
This is my present albatross and the reason this beast hasn't moved since getting smogged. I have confirmed the pump actually works by hooking it up to independent power. Doing that the car will start and idle. Wants to stall with any throttle unless I'm careful but I'll worry about that later. I've also bypassed the fuel pump relay on the off chance that it shat the bed. Unfortunately for me the relay and resister's bowels appear to be intact after all. This led me to think back on the tail light dilemma, so I first checked continuity of the ground strap for the pump...reported back okay and with no abnormal resistance. So as a sanity check I attacked the pump's ground point and bolt with my dremel anyway...and man was it needed. The thing was practically caked in corrosion...the removal of which changed precisely 0.00 fuckalls.
So between my wrist starting to click again and my tweaked shoulder threatening secession I had to stop for the day. While I have a Denso TT fuel pump and a much nicer gas tank waiting to install, I know this pump still works and want to figure out this problem before putting the upgrades in place and still having this issue drive me bugnuts. Hopefully my next update won't take so long! (hah, this damned machine clearly has it out for me)
Kamikaizen
Authorized Seller
Joined
Mar 17, 2018
Messages
Location
Longmont, CO
All right! An update, fuck yeah!
Anyways. Long story short, that fuel pump was le toast. I suspected it was going out, and after comparing resistance of it - a whopping 18.5ohm - against my new Denso TT pump at 1.3ohm pretty much confirmed it, since electrically everything upstream was behaving; circuit opening relay, fuel pump relay, etc etc. After all the fun of recapturing the fuel, which I wasn't expecting six gallons when the needle was below 1/4 full, and a few key flicks to prime the system again she finally stumbled back to life.
As part of the pump swap I also procured a good condition gas tank, since mine was given a Reduced Capacity mod and caved in badly on one corner. I'm just lucky it didn't hit the pump or float area...but it came awfully close. New gaskets all around and I even picked up one of the last remaining five, per my dealer, fuel cutoff valves left and threw that in. It likely wasn't needed but y'know, I don't want to have to drop a fuel tank a second time. I even went so far as to pickup a tank sealing kit in case it had pinholes. I gave it the wash and rise phase, but after noting no leaks at all I opted to forgo the urethane coating.
Forbidden apple cider anyone? :D
And while I was at it, I decided to clean up the wiring to the ISCV. After peeling away the ancient electrical tape I was horrified by the sight before me:
Almost every wire was previously spliced...TWICE. What the shitlicking christ. To make it even better, one terminal was just plain gone; it had bare stranded copper just kind of jammed into the connector. And bonus; two of the wires were freaking backwards. Small wonder I had so much idling difficulty before. So, brand new plug with fresh copper went on. I even used a rubber boot for the connector I had laying around because why the fark not:
Yeah it's a bit longer than needed, but it doesn't interfere with anything and for now I am still in Removing Previous Owner Mods phase. Much as I want to dive into juicy modding and making this machine my own, I can't in good conscience do that while the wiring is so horrendously basketcased and the motor I know is a bit on the tired side. So for now I continue with repairs as necessary, and upgrades along the way when available, like replacing the original starter high tension lead with new 2awg. The original cable was stiff and crispy, so even if it ohmed out well I didn't feel like investing trust into a cable that was made when Mark Zuckerberg wasn't even in kindergarten yet.
Only problem now: in my fatigued state of mind I idiotically put the throttle body gasket upside down, so it's now hissing worse than Snakes On a Plane and prefers to idle at 1500 instead of a more civilized 650, but I'm just going to replace that gasket anyway since it's been heavily compressed by now.
xCxHxRxIxSx
Authorized Seller
Joined
Mar 4, 2011
Messages
82
Location
Oakville, Ontario
Great thread! I'm enjoying following your progress on bringing her back to life. Keep up the good work, and hopefully she doesn't have too many more surprises in store for you lol
Kamikaizen
Authorized Seller
Joined
Mar 17, 2018
Messages
Location
Longmont, CO
This is a small update, but one that's been needed especially since Colorado has evidently been in its monsoon season lately.
Long story short, the driver window regulator is shot to shit. The glass doesn't go all the way up, nor does it stay level, and the motor gear of course pops enough to get even Orville Redenbacher's attention. All of this leads to my getting the occasional unwanted, spontaneous douche if there's any significant rain. Thus! I get to deploy some more of my fresh parts hoard! Now, let's queue the music.
First up, the ungodly state of the original regulator. I knew there'd be a stripped gear and possibly slop in the tracks. But I did not expect the bloody track itself to be bent to the point where the roller nearly falls out:
And for more previous owner goodness, they managed to - somehow - shear off one of the four mounting tabs for the motor side of the assembly. And I don't mean it was broken off while they were fucking around and just slapped it back in. I mean that tab was Still Bolted In Place:
Luckily I had a much healthier assembly sitting around. But, I wasn't in a mood to trust another 31 year old motor, so I replaced it with a new VDO unit. I also used this opportunity to restore the pile on the felt window bumpers.
Before:
And after:
...okay that's shittily out of focus but you get the idea. I'm no photographer. Sue me :p
Obligatory shot of the new assembly before it went in. I cleaned out and greased up all the tracks, gear path and hinge before putting this whole thing back together as I really am not interested in repairing the same thing twice.
That's it that's all for right now. Eventually I'll do the same on the passenger door but it's not in nearly as bad shape. Next up will probably be replacing the diverter valve with a Kayser 710n or such since I'm beginning to think my lack of boost is at least partially to blame on that. But she starts and drives and boosts at least a little. :)
plaaya69
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,572
Location
Lake County, IL
Very clean install Kamikaizen. Did you find those new felt window bumpers from the dealer?
Kamikaizen
Authorized Seller
Joined
Mar 17, 2018
Messages
Location
Longmont, CO
They're not new; I just spruced up the original ones by carefully using a brass detail brush to fluff the nap on them back up. I'm not sure if they're even still available from the dealer though I'm pretty certain the exterior trim with its two felt pads is NLA. YotaMD has a video on Youtube about restoring them which is where I admittedly got the idea from and it's made a dramatic improvement in the window rattle
Kamikaizen
Authorized Seller
Joined
Mar 17, 2018
Messages
Location
Longmont, CO
Late morning motivation kicked in and I finally got around to a little mod I've been wanting for a long time.
It's pretty simple: Fan pattern windshield sprayers! Only problem; pre-89 hood means pre-89 nozzle footprint. So to tackle that I cut out a section of my RAV4's old hood to use for a cutting pattern:
And here's the upgrade. IIRC they're off an `05 Camry:
I also did have to open the hole on the hood reinforcement a little since these have an angled hose barb. But that was fairly trivial in and of itself. And to finish off this mini update, a quick test of the new sprayers :)
Kamikaizen
Authorized Seller
Joined
Mar 17, 2018
Messages
Location
Longmont, CO
Well, this would have been about the time I would drag the MA70 out of cold storage and start having fun. Buuuuuuuuuuuut, fun has been officially canceled until dogs-only-know when.
So with my newfound free time I started scraping together some stuff to finally have fresh suspension. Nothing crazy; just a set of OEM struts, some RS-R springs since I missed out on finding Eibachs before they went the way of the thylacine, and the usual hardware and spring silencers.
But the riddle of the front spring isolator was sitting there staring me in the face like some inbred first cousin. I've read through the threads on here about this issue and noted the various cushions that were tested and/or used. From that I nabbed myself a set of Energy's 9.6107 isolators. But when they came in I was not happy with how much lateral slop I was seeing. The other option didn't sound any better so I shelved the project for a while... That is, until I was organizing parts for my better half's restoration project and noticed a pair of poly spring isolators. They were pretty big and beefy and just for s&g's I tried them out expecting them to be hilariously oversized.
...instead I was met with an amazingly good fit. The inner lip hugs the spring coils fairly well without being a fight to fit them on. The lip is also slightly taller than the wire thickness so it's not liable to slip free. When I positioned it on my crappy KYB top mounts I noted at most about 5mm of lateral travel; easily half that of the other isolators. It seemed practically perfect. :D So I did the prudent thing and got another pair for myself. After shimming the top mounts so it's not riding on just the mounting studs I now have a set of struts and springs to put on the beast and finally be riding on something other than third of a century old springs and long since zombified struts.
It's not much, but it brings me happiness for now.
  • Like
Reactions: debrucer
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
2,301
Location
MKE, WI
Lookin good.
I like the isolators. ;)
Hacknsmack
Authorized Seller
Joined
Jul 13, 2014
Messages
14
Location
Tennessee
I’ve been going crazy looking for some front spring isolators. Any downsides from the poly set you installed? Like riding issues, spring movement or any absurd noises?
Kamikaizen
Authorized Seller
Joined
Mar 17, 2018
Messages
Location
Longmont, CO
Whenever I can get them installed and tested I'll be sure to post up my findings. :) My Supra's been in storage for the winter and with the lockdowns I haven't had much of an opportunity to bring her out of mothballs. It probably won't be for another couple months until I can find out of this is truly viable, but I am confident they should suit well based on their initial fitment
Hacknsmack
Authorized Seller
Joined
Jul 13, 2014
Messages
14
Location
Tennessee
Looking forward to hearing how things work out on your end. I really need to change my ride setup, car sits too low for my liking. Lately I’ve been bored out of my mind with these lockdowns going on, trying to sort out my projects lol. In the meantime I’m going to finally get around to replacing my door and fender, along with the targa seals. I gotta repaint the top as well. So that’ll keep me busy for a bit while I figure out the suspension route I want to go.
Kamikaizen
Authorized Seller
Joined
Mar 17, 2018
Messages
Location
Longmont, CO
Not much of an update, despite all the stuff I've been getting done on the beast lately.
For starters, someone removed the rear speakers without putting anything in their place. Also what was left of the foam was absolutely skanky: IMG_20200721_175534097.jpg
So a bit of elbow grease, plenty of orange oil and a plastic scraper later the boxes cleaned up nicely. I also decided to throw some fresh self-adhesive foam in as close to the original dimensions as I could conveniently find:
Not by any means perfect, but it stays and seemed to fit back in place just fine. And went with the obvious Polk db501s for the rears as I can't seem to find any other speakers even close to 4T.
So that I could take advantage of the audio repairs, and have something other than the factory-muted straight-6 soundtrack, I threw in a working head unit to take up the gaping cavity that's been in the center console. Glad it mated up without any issues but someday I'll want a more modern head unit:
In a small little splurge I decided to have a little fun and slapped in my Euro turn signals. Really like their look:
And to go with the lighting upgrades, I fitted some yellow Lexus capsules into the fog lights and they look beautiful as well as doing their job better now. :) But my crapass phone's camera can't take a good picture to save its own life, so instead I attempted to take a legible pic of the gauge cluster lighting. Even got the cruise/defrost/fog switches even though that's not shown on the pic:
Moving along to the main purpose of her latest downtime; those stupid front wishbones. Their bushings were badly shrunken, leaving me with drunken steering on the highway which I absolutely did not like. So I went for the easy option and got an Energy Suspension kit and slapped them in my spare wishbones, which were heinously filthy and caked up enough to require scraping off before I could brush off the rest. Without further adieu here's the obligatory before and after shot of them!
I don't expect the bushings to make NVH much worse, but I haven't driven her on these yet since I'm still waiting for other work. Along with this I took the chance to throw my new struts and RS*R Down springs on. The poly upper spring bushing I'm using up front had no trouble fitting in the shock tower despite being bigger diameter than the top mount, so that was a relief:
Because my laundry list of work items keeps growing, I replaced all the trunk area interior panels since they were all chewed up, had pieces broken off, nonexistent screw holes, etc. This car has obviously been mistreated in the past so I feel a bit duty bound to correct that as far as my abilities can go.
I also wanted to try and resolve that audible exhaust leak I hear any time the turbo spools up. I kinda suspected the manifold gasket since I can hear the individual exhaust pulses from it, and I'm tired of experiencing barely 4 PSI of boost :p Lo and behold I was met with two surprises.
1) Someone replaced the manifold already, as noted by the junkyard markings on it. And literally all seven nuts holding it on broke free with barely any effort. While I don't have a flatness gauge it was painfully obvious with the unaided eye that the exhaust manifold was brought to me by the Frito-Lay Corporation; damn thing is warped as much as my longbow and has a lovely full length twist in it to boot. So it wouldn't seal even if I tried. :/ Guess it's time to find a machinist to see about milling it flat if possible. Or maybe straighten it but I don't actually know if that's feasible with cast iron. I'll let a professional figure that out for me.
2) Despite being an '88, I apparently have the late model 7M block. Saw the extra reinforcements staring me right in the face after yanking the manifold:
So, yeah. o.o; Saves me the time and cost of getting one I suppose! If it also has the 7M crank I'll be absolutely gobsmacked. In a good way. :) After this job is done - and probably get the turbo rebuilt since now's a prime opportunity - I just have to get the 6-½" speaker pods thrown in and some nicer looking door cards and maybe then she'll feel nice and healthy.
Kamikaizen
Authorized Seller
Joined
Mar 17, 2018
Messages
Location
Longmont, CO
Another tiny update while waiting on Yet More Parts Shipments.
After a bit of research and poking around I was able to reverse engineer the BIC engine torque solid strut mod. I found a Prothane kit that had the exact right length to it (approx 7-¼") and it installed with ease. Didn't even have to drill out the brackets :)
