Supra Jerks when stepping/letting go of gas...
bsupra
Authorized Seller
Joined
Oct 1, 2006
Messages
200
Location
California
I previously own a 89 supra turbo. I remember every time I let go of the gas, it has a smooth deceleration.. On my 91 turbo, every time I let go or step of the gas, there is jerk fwd/back. I checked timing and TPS and they are pretty much in spec.....Any suggestions? Thanks
suprarx7nut
YotaMD.com author
Authorized Seller
Joined
Nov 10, 2006
Messages
4,176
Location
Arizona
Agreed with the mounts. Engine mounts can be completely torn and non-functional, but can look fine. When I've pulled engines on high mileage cars they've been consistently ripped or torn, but I didn't know it until I started lifting the engine.
I should really get around to replacing my trans mount...
MkiiiAllDay
Authorized Seller
Joined
Jul 19, 2013
Messages
159
Location
orange, CA
Is the jerking intense like it could be motor? If not it could be tans and diff related if it's slight Cuz i get a slight jerking in low gears, but that's do to diff backlash
f00g00
Authorized Seller
Contributor
Joined
Jul 2, 2007
Messages
626
Location
Kuwait
I had a dead spot on my tps that caused that issue when I had a 7MGE.
bsupra
Authorized Seller
Joined
Oct 1, 2006
Messages
200
Location
California
It feels like somebody just bump your rear bumper/ front bumper when you step/let go of gas pedal....
bsupra
Authorized Seller
Joined
Oct 1, 2006
Messages
200
Location
California
I have checked the engine mounts... Both sides look good physically and there is a small amount of tilt when I rev the engine....
I think you are right... It maybe the transmission mount... I can here a clunk when I every time the car jerks when I step/let go of the gas pedal. I will try checking the transmission mounts this weekend.
f00g00
Authorized Seller
Contributor
Joined
Jul 2, 2007
Messages
626
Location
Kuwait
I forgot to mention that when my car had the same problem the jerking ended up breaking my rear subframe.
It was probably the most power my NA had. If you have another TPS by all means try it.
I was lucky enough to find a rear subframe here in Kuwait at the junkyard at Amghara. Now there are 0 Supras in the yards since they had the yards moved to the middle of nowhere and there are maybe a dozen MKIII's on the road.
bsupra
Authorized Seller
Joined
Oct 1, 2006
Messages
200
Location
California
Thanks for following up, that's some commitment almost five years later!
LOL... Yeah, I stopped working on it and just tried to ease up on the throttle when releasing it...
Until one day, youtube posted a recommended video about dashpot's lol. Sure enough, the screw stop was barely touching the screw stop when I checked it. After I justed it, issue was gone almost instantly.
