Stalling when revved
mk3_manny
Authorized Seller
Joined
Dec 4, 2018
Messages
11
Likes
I took out my VAF/MAF sensor to clean it (with the right cleaner), when i went to plug it back in, the car wouldnt start. i realize my wiring on my sensor was loose so i rewired. The car now starts and has a fairly good idle, but when revved up engine stalls out. If accelerated at a constant speed its fine, but when its revved it simply looses all power and stalls. Last time i revved it, smoke came out close to where the turbo is located. Do you guys have any suggestions? (7mgte in an 89).
shadowman1977
Authorized Seller
Joined
Jun 4, 2015
Messages
170
Likes
5
Location
Kingston N.Y. 12401
#2
Hey man, I’m having a similar issue. Try disconnecting the TPS and see if it still happens. If it doesn’t, try recalibrating your TPS. That may help.
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
1,574
Likes
117
Location
MKE, WI
#6
If its the stock maf its completely sealed as its a vortex street style sensor
The stock karman vortex sensor is not totally sealed.
There is a pressure directing hole or path from where the oscillating vorticies are generated up to the small mirror and photo transistor.
If you clean the sensor with any product other than what pi mentioned above you will risk contaminating the mirror / photo transistor.
mk3_manny
Authorized Seller
Joined
Dec 4, 2018
Messages
11
Likes
i disconnected it, tried to recalibrate, ended up buying a new tps from toyota and its still happening
mk3_manny
Authorized Seller
Joined
Dec 4, 2018
Messages
11
Likes
Check for leaks with a turbo air systemtest kit, check for oir loss, oily tail pipe...
doesnt seem to be loosing oil, but there is definetlly oil/gas in exhaust. might not be a turbo leak, but i notice a leak coming from the right side, cant identify where it is exactly
3p141592654
90T
Authorized Seller
Contributor
Joined
Oct 11, 2005
Messages
4,097
Likes
69
Location
Thousand Oaks, CA
#13
code 31 is probably a wiring or connector problem with the AFM. It could also be a bad AFM sensor.
Car will run badly in limp mode with code 31. Needs to be fixed.
don't worry about code 51. Could be TPS not calibrated, or just the AC left on.
shadowman1977
Authorized Seller
Joined
Jun 4, 2015
Messages
170
Likes
5
Location
Kingston N.Y. 12401
#14
I thought it was sealed, my bad. I may very well have damaged mine also. Think I used brake clean assuming it was a sealed unit with a photo sensor like a cad cell eye on a furnace.
mk3_manny
Authorized Seller
Joined
Dec 4, 2018
Messages
11
Likes
every diagram i found was the same, i replicated that, the only thing where i mightve messed up is by mixing up the brown wires
shadowman1977
Authorized Seller
Joined
Jun 4, 2015
Messages
170
Likes
5
Location
Kingston N.Y. 12401
#16
Just checked mine today apparently the other protrusion from the sensor is broken. Probably why I can’t get the RPM’s up without stalling on the way down FML!!! :(
