Springs
Wiisass
Authorized Seller
Contributor
Joined
Apr 24, 2005
Messages
735
Location
Philly
I would like to compile the different rates of what setups are available on the market. So lowering spring rates, coilover spring rates, etc. I know I found a good list a while back, but I'm not sure if that is accurate anymore or if many of the setups are still sold.
I will also be going into how to pick spring rates, what goes into the selection and how to balance the car with them.
Tim
figgie
Authorized Seller
Contributor
Joined
Messages
5,330
Location
Shakopee, Minnesota
Adding to this as this will help with the information.
Brought to you by none other than Claude Rouelle.
(For those of you that are math challenged, forgo this and brush the math/physics skills up as this goes DEEP into mathematical equations and some physics).
Mk3runner
Authorized Seller
Contributor
Joined
Nov 19, 2006
Messages
2,033
Location
Nor Cal
Link posted on post 2 is no good.
Any updates? Maybe the link was moved somewhere?
ma71supraturbo
Authorized Seller
Contributor
Joined
Messages
975
Location
Redding, CA
That link was probably moved here: http://www.mkiiitech.com/forum/showthread.php?t=116
My post in that thread also has dead links. The current links are:
lower spring rates:
http://www.geocities.com/ma71supraturbo/MK3Tech/LoweringSpring.html
coilover spring rates:
http://www.geocities.com/ma71supraturbo/MK3Tech/Coilovers.html
Note that that info is from ~2004-2005. I also only used the spring rates for the 89+ stock springs...
