Spark plugs ??
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
1,858
Location
MKE, WI
Why?
This product is a solution to a problem that does not exist.
Get a good set of NGK plugs, properly gap them and don't worry about it.
How much are these things anyway?
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,388
Location
Shakopee, Minnesota
ahhh!
I see that the many prongs is back!
bosch +4 Plats
Splitfires
NGK Multi prong
those were the old versions.
Long story short,
1 spark event regardless of how many prongs.
Madboost
Authorized Seller
Joined
Apr 19, 2019
Messages
31
Well that’s just that one style it’s says it better for boosted applications there are different ones but the thing I’m looking at is heat range ngk you can only go 1 step colder these you can go like 8 steps colder not just this style plug but this company itself
3p141592654
90T
Authorized Seller
Contributor
Joined
Oct 11, 2005
Messages
4,097
Location
Thousand Oaks, CA
Those triple electrodes were OEM on Volvo NA 5 cylinder engines. However, for the Volvo turbo 5 cylinders they used single electrodes. Food for thought.
Madboost
Authorized Seller
Joined
Apr 19, 2019
Messages
31
See everyone says one step colder but I just came across some info that says one step colder for every 100hp over stock? I’ve never heard that before till now
f00g00
Authorized Seller
Contributor
Joined
Jul 2, 2007
Messages
620
Location
Kuwait
The turbo spark plugs are single electrode on the link.
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,388
Location
Shakopee, Minnesota
it is best to run a plug then read the plug. Reading the plug will tell you all that you want to know about that particular plug in your application.
  • Like
Reactions: Madboost
