Slotted Rotors..Direction
JD7Monster
Authorized Seller
Joined
Jul 6, 2005
Messages
Likes
Location
Orlando, FL
#1
Alright.. My CD/Slotted rotors just came in..
Now.. I've seen diff cars with those rotors facing different ways..
Can someone tell me which one is right in my crappy diagram?
A or B..?
whopwood
Authorized Seller
Joined
Jun 27, 2005
Messages
56
Likes
Location
Madison, WI
#2
Never owned a set, but if the groves were not supposed to throw debris outward, I would be surprised.
I'd assume choice A.
JD7Monster
Authorized Seller
Joined
Jul 6, 2005
Messages
Likes
Location
Orlando, FL
#9
I'm getting replies before I can reply..lol I'll probly end up going with what both links say, I trust brembo.. also the "Vanes" are strait, and according to brembo that means they're non-directional.. i'll use that
tlo86
Ninja Editor 'Since 05'
Authorized Seller
Contributor
Joined
Jul 24, 2005
Messages
3,914
Likes
Location
Colorado
#10
i didn't consider this when buying my brembos... i'll do what brembo says and go with b ;)
K
karaki
Guest
#11
"All curved vane rotors are installed with the vanes pointing to the back of the car...to be more specific...if you put a pencil in the vane(top of the rotor)....the pencil will be pointing to the back of the vehicle."
According to Rory at Coleman Racing
K
karaki
Guest
#13
Thanks...looks like it's time for you to get another one. As much as love my MK3 with a passion i wouldn't be able to live without my mk2...completely different beast...I miss her :cry: ...been off the road since october for a full restoration and some major @$$ upgrades...ciao.
**sorry...didn't mean to hijack this thread**
bluemax
The Family Man
Authorized Seller
Joined
Messages
418
Likes
Location
Orange County, CA
#14
The vanes are on the inside of the rotors.
The slots on the outside of the rotor are not the vanes.
So you might want to check to make sure the slots are in the same direction as the vanes. I think the practice it to slot the rotor in the direction of the vane, but that doesn't mean the shop that made your rotors did.
Most rotors are not directionally vaned.
In that case, it really doesn't, matter which way the slots go. I'm told the standard practice is for the top of the slot, when the slot is at the 12 o'clock position (outer edge of the slot nearest the outer edge of the rotor), to be the leading edge as you drive forward.
JD7Monster
Authorized Seller
Joined
Jul 6, 2005
Messages
Likes
Location
Orlando, FL
#15
The vanes are strait up, so i guess it really doesnt matter which way i put it..
I'm gonna end up putting it the way brembo, baer, and bluemax said.. style B.
Adjuster
Authorized Seller
Contributor
Joined
Apr 8, 2005
Messages
1,166
Likes
5
Location
Meridian, Idaho, United States
#16
Good choice with style B. (That's how mine are, and how every slotted rotor I've noticed lately is. (When installed correctly.)
My rotors use curved vents, and when moving, pump air from the inside out. (Hub out.)
Troyota
I Love What You Do For Me
Authorized Seller
Joined
Jul 28, 2005
Messages
243
Likes
Location
Roswell NM
#17
The MKIII's Rotors are not directionally vained...I have mine set-up w/ style A because they are both slotted (curved slots) and cross drilled and I think it looks better that way. My AE86 has just slotted rotors and they are set up as style B because the slots are straight and are designed to scrape the surface of the pad to make a clean mating surface to the pad to rotor contact.
1TuffSupra
Sho' Nuff
Authorized Seller
Joined
Jul 11, 2005
Messages
500
Likes
Location
Raleigh, North Carolina, United States
#18
It depends on the style of rotor, like it was mentioned before, you should orient the rotors in the direction so that the vanes (inside the rotor) will allow heat/air to escape the easiest. For Baer brakes (style B) it looks like it is off, but for their rotors that is the way they are installed since the vanes inside the rotor flow in the opposite direction.
Braketime
Joined
Jan 24, 2019
Messages
Likes
The image that you had uploaded is not available anymore. so, it was hard to make out which types of diagrams did you draw. Anyway, the
braketimeusa com brake drums best method will be to go by the rules Brembo has explained. They will know it better than any of us.
twin2turbo
Authorized Seller
Joined
Apr 1, 2010
Messages
68
Likes
Location
Mill Creek, Wa
#20
its not available anymore because this thread is from 2005 lol
