RS-R Ti2000 Down Springs
alcyon
Authorized Seller
Joined
Jun 15, 2017
Messages
188
Location
Kuala Lumpur
I ordered these more than a month ago and they finally arrived.
Part Number T160TD. Titanium infused lowering springs. Front Rate 7.2K, rear 3.15K
Anyone knows the front springs length? I measured here this one from a 87 GZ20 Soarer is 340mm, the RSR are 290mm. If I remember correctly the ones on my 89 are 320mm. I always thought that if I wanted a 25mm drop the springs free length should only be about 12.5mm shorter than stock. Is there something wrong here ?
Another problem is the spring lower opening is too small, I cant fit it completely on the perch. Opening 63.5mm
old spring sits in perfectly, opening 66mm.
Just my luck . I thought I could just install this. I lodged a complaint with RHDJapan about these.
Any thoughts on the lengths ? Are these RSR downs (-1") or super downs (-2")?
alcyon
Authorized Seller
Joined
Jun 15, 2017
Messages
188
Location
Kuala Lumpur
Latest update, i decide to try fitting the RSR spring onto my old original 1989 TEMS shock, and it fits perfectly. Thats odd the earlier series shocks wont fit these springs.
The spring length also seems to be correct. I measure the distance from perch to bottom of rubber isolator mounted, its 279mm. The springs free length is 290mm, so its pressing against the bottom and the top when released.
sinistar_xx
Authorized Seller
Joined
Dec 28, 2018
Messages
169
So is it the KYB Super Special struts that the new springs are not fitting on?
alcyon
Authorized Seller
Joined
Jun 15, 2017
Messages
188
Location
Kuala Lumpur
They fit to my old tems shocks so these should fit on my new kyb tems. I will only work on my car the coming week as its not with me now.
