ride height
sinistar_xx
Authorized Seller
Joined
Dec 28, 2018
Messages
113
For what year? Pretty sure 89+ stock height is slightly lower.
Not sure about the where to measure part.
Dave 1jz
Authorized Seller
Joined
Feb 16, 2010
Messages
Location
rotterdam
This is all mentioned in the TSRM, you measure it from the center of the LCA bolt to the floor
Dave 1jz
Authorized Seller
Joined
Feb 16, 2010
Messages
Location
rotterdam
You will need to compensate for different tire diameters if deviated from stock size. Then you will have the exact numbers how much the car and also the suspension is lowered.
  • Like
Reactions: sinistar_xx
Koenigturbo
Authorized Seller
Joined
Oct 4, 2006
Messages
1,495
Location
Oxnard CA
You nailed it, that's exactly what I'm trying to determine.
sinistar_xx
Authorized Seller
Joined
Dec 28, 2018
Messages
113
So for 89+, there was a drop in height by 12mm. I'm assuming that drop is from shorter springs, but would that also affect the ride height measurement as shown in the TSRM? I'm not really sure how one affects the other, so just curious.
Dave 1jz
Authorized Seller
Joined
Feb 16, 2010
Messages
Location
rotterdam
That depends on the ride height. My car is lowered 40mm and the front lca is still pointing downward from the subframe to the wheelhub. The rear i slightly pointing upwards at 40mm lower. There is another thread on how to measure this.
  • Like
Reactions: alcyon
