Recommended replacement heater core?
loc182
Seven Empowered!
Authorized Seller
Joined
Jul 3, 2013
Messages
386
Location
Bothell, Washington
Answer 1:
So the core itself will fit into the large void, and the pipe looks to the be correct length, but I could not get a Toyota pipe to fit into it any further than the wide area where the o-ring would live. I twisted and pushed firmly, but the pipe would not slide in at all.
I didn't push too hard, as I didn't want to get anything stuck or damaged. Plus the pipes slide in and out of my OEM core with ease, I am assuming that is expected.
UPDATE: Rock Auto got back to me and said that of the 41 units of this model they have sold I am the third person to complain about the piping. So maybe when you order you have a chance of getting one that is correct?
Answer 2:
Both the long and short pipes appear to be soldered in place.
Here are some more pics. I found it interesting that the Spectra sits ever so slightly high and doesn't seem to account for the metal piece in the bottom of the plastic core housing. (Guessing this is for turning on the auto heat.)
kmtsd
Authorized Seller
Joined
Mar 28, 2019
Messages
5
Wow sorry for recommending that Spectra part. I had no issues with mine that I ordered since I've installed it. The pipes were oriented the correct way and it fit right in. Maybe Spectra labeled the the one you received wrong and it is for a different car?
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
1,993
Location
MKE, WI
They are likely manufactured sloppy. Or someone screwed up the alignment jig there.
loc182
Seven Empowered!
Authorized Seller
Joined
Jul 3, 2013
Messages
386
Location
Bothell, Washington
Hey no worries at all! I bet Piratetip is right, some come out good, some are not so good.
I am just glad you got a good one!
loc182
Seven Empowered!
Authorized Seller
Joined
Jul 3, 2013
Messages
386
Location
Bothell, Washington
Curious if anyone has a picture of the ECU and ABS computers installed? I cannot remember how they were held in place and or how to search Supramania with 3 letter words :(
Close to having the car back together, don't let me down new o-rings!
  • Like
Reactions: debrucer
loc182
Seven Empowered!
Authorized Seller
Joined
Jul 3, 2013
Messages
386
Location
Bothell, Washington
I did find an old post that reminded me of how to search!
<THREE LETTER WORD>*
So abs* and ecu* should work, only problem is abs* will return things with absolute and so on, whilst ecu* will find ecumenical. The latter is probably less of a problem of course :p
Sadly haven't found a pic yet, but I will warm up and try again today. I didn't think it was too complicated, but I should have taken pics of everything during the tear down. (To be fair I was expecting to re-assemble that day.)
  • Like
Reactions: sinistar_xx
loc182
Seven Empowered!
Authorized Seller
Joined
Jul 3, 2013
Messages
386
Location
Bothell, Washington
A good night's sleep and more lamps got me back in action. Here is a pic for Debrucer!
What threw me (beyond being cold, bleeding, and tired) is the ABS wires sort of twist when the unit it lifted into position. This made me think I had the unit backwards when I actually had it correct.
  • Like
Reactions: Piratetip
loc182
Seven Empowered!
Authorized Seller
Joined
Jul 3, 2013
Messages
386
Location
Bothell, Washington
So now that enough time has passed and things seem good I can say that although I didn't need to pull the dash or heater core my coolant issues are gone :)
Bottle is holding steady like it should when cold and no more birdcage after a couple of days.
My guess as to what was happening...well, I replaced a generic clamp with the Toyota one on the hose that runs to the horrible union on the back of the head. The old clamp was covered with crusty coolant, so it must have been allowing some to escape. it is just odd that the coolant was climbing the hose.
  • Like
loc182
Seven Empowered!
Authorized Seller
Joined
Jul 3, 2013
Messages
386
Location
Bothell, Washington
My guess is that the part you are trying to get will be endlessly back-ordered.
They probably no longer make it anymore.
I was home when Car ID called today and I finally cancelled the order for the OSC :p
They asked if I was sure I wanted to cancel and I said, yep, it has been back ordered for 14 months now!
