Rebuilding CPS - Source of NEW Coils & Waveform Signal Analysis
MarkIII4Me
Project OVERKILL!!!
Authorized Seller
Joined
Apr 10, 2005
Messages
1,294
Location
Charleston, SC
Had an extra CPS on a shelf. I went to check the air gaps, and to my surprise, all 3 coils are green. Color is not as vibrant and as the newer ones posted. The wiring also appears to be original as well. Does this look like a reman'ed unit?
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
2,411
Location
MKE, WI
It does look like a reman, but the wires look older. Which is a bit odd.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,411
Location
MKE, WI
It was either Grainger or McMaster.
Just a 4mm pin.
Though had to buy a pack of 25. :)
  • Like
Reactions: figgie
MarkIII4Me
Project OVERKILL!!!
Authorized Seller
Joined
Apr 10, 2005
Messages
1,294
Location
Charleston, SC
Opened the CPS on my engine and it too appears to have green coils, though a darker green than the others posted; like an OD Green.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,411
Location
MKE, WI
Is that a cardone rebuild?
MarkIII4Me
Project OVERKILL!!!
Authorized Seller
Joined
Apr 10, 2005
Messages
1,294
Location
Charleston, SC
I don’t think so, since the original paint is still on the coil screws. This CPS either came off the original 1990 7mgte I took out or the imported jdm engine I had torn down. My current engine I purchased as a long block with no CPS. It’s strange; out of the 3 CPS’ I’ve inspected in the last few months, 2 had some form of green coils installed.
The 3rd looked like just about any old CPS I’ve seen in the past.
MarkIII4Me
Project OVERKILL!!!
Authorized Seller
Joined
Apr 10, 2005
Messages
1,294
Location
Charleston, SC
setup->Sensors->cam/Crank->Advanced Cam Crank->Advanced Pickups
Crank H Sens Below 1200
Crank L Sens Above 1200
Cam High Sens Below 1200
Cam Low Sens Below 1200
I would venture a guess that you are probably not outputting as good as the 1st scope image as PirateTip posted.
this might definitely help your issue!
Any reason I can’t adjust these settings? Any value I change defaults back to 6000. Doesn’t seem like I can adjust much of anything, as if the settings are locked. Any idea how to unlock them?
