Project AutoX
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
2,356
Location
MKE, WI
Do you have foam seals around the entire perimeter of the fan housing and radiator to condenser/vehicle frame interfaces?
If you don't its a path for the air to bypass going through the radiator before being sucked through the fan/housing.
I made sure to entirely seal my radiator to force all the air through it.
Just another idea.
Also do you still have an underguard?
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
Just another idea.
Nope, no foam, and probably wouldn't hurt to try it. I have an undertray I bought new from toyota a few weeks ago, after installing though James Ward agreed with my observation that it makes them run hotter, which he has also experienced in the past. At this point, unless something comes up in the summer the cooling system is working very efficiently, taking between 40 and 50 degrees off from top to bottom, either sitting still or moving, I will do more testing in the summer, but for now I am happy with the cooling system.
  • Like
Reactions: debrucer
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
Well, I finally made some headway on the issue it seems. The problem ended up actually being very simple. All along I was putting the thermostat jiggle valve at 12 o clock as I was taught and have always done. There was one issue with this, my opinion on 12 o clock and toyotas opinion on 12 o clock when designing the engine were quite different. I ended up having the jiggle valve 90° off of the mark on the lower waterneck. Which I'm guessing most likely resulted in very large air pockets and a lack of flow and cooling issues. I took it apart, turned it to the correct location and burped it the best I could. I even took 2 heat cycles to burp it just to be 100% sure. I just got done idling the car for 30 minutes in 40 degree ambient temps, and while the ambient temperature isnt pushing the cooling system as hard as it could be, a dead idle for 30 minutes straight allows it to make plenty of heat to show any fault in the cooling system. The results indicated that at the stop of driving the car was at 191°f, it stayed this way for 17 minutes until the temperature dropped to 190° and by the 30 minute mark the temperature had dropped to 188°f! It seems that it is finally truly fixed! Time will tell when it gets warm outside, but for now it seems to be doing nicely.
  • Like
Reactions: debrucer
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,356
Location
MKE, WI
Yup, good find.
I was going to ask if you clocked the thermostat correctly.
Another method is to drill it out and enlarge that hole slightly, but should not be necessary.
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
Yup, good find.
Yeah, seems to be doing good now, I'll just have to watch.
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
The dates for this years Supras In Vegas have been released, gonna put down for vacation time tomorrow! Really have to make sure the car is sorted since it will get about 5 thousand miles put on it in the course of 2 weeks.
  • Like
Reactions: debrucer
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,356
Location
MKE, WI
What are the dates?
I'll have to see if I can line it up with when I travel there for work.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,356
Location
MKE, WI
Ah ok.
So a ways out then.
debrucer
It's about the journey
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
496
Location
San Diego, California, United States
Cannot imagine 5000 miles in my Supra, either from a comfort standpoint, or trust :) It's only a six-hour drive for me, and I can't fully imagine that either. I'm thinking I'm too old for that... maybe in my younger days. Maybe you want to fly to San Diego and drive mine to Vegas... I'll fly and meet you there :) Well, that's one idea. lol
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
I'm planning on driving to California after vegas, I was hoping to see the golden gate bridge so I might have to hit you up!
  • Like
Reactions: debrucer
debrucer
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
496
Location
San Diego is probably a full day's drive out of the way... not a bad place to visit, but no golden gate here. I have told friends, SIV 2020, and I've enjoyed the videos on youtube... committing to October would be way too much pressure. I hope to be closer, but, I doubt I'll be road-worthy.
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
Well, that shows my Kentucky geographical ignorance, I thought San Diego was San Francisco for some reason! Hopefully it's done by then! I'd love to see some cars with build threads out there for sure!
  • Like
Reactions: debrucer
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
One of my goals with the assembly of this car is to modify it in such a way that what I do is what in my opinion Toyota might have done to the car if they rereleased it right now in 2020. Part of bringing the car into the current decade is exterior lighting. While I had LEDs for all the parking lights and the headlights already, I was undecided on what to do with the stock fog lights. After much thinking I decided to go with Dustin Gurley at double bounce extrusion on the foglight upgrade that he offers. I liked this setup because unlike the other options offered currently his design is a very nice flowing shape with the front bumper. He had 3 options at the time I ordered, now he only has 2, the v1 and the morimotos. The major differences being that the v1 has a much better light output, but the morimoto lights have a longer warranty. I opted to go with the v1 for light output because unlike the morimoto which is less bright and seems to be more of a halogen color, the v1 has 3 LEDs and 3 projector lenses in each light resulting in a major light output and beam spread, along with a super sharp cutoff.
I ordered these fogs with his tweeter upgrade that he also printed but I have not installed at this date. They are sitting until I install the 91-92 blue door cards I have sitting for the car. After waiting for a bit because he had printer issues I finally recieved the parts. Upon opening the box they were very well packaged and the initial quality of the parts was superb! Needless to say they were well worth the wait. In the box you get the lights. Which are plug and play, the bracket, which also bolts up, you just have to trim a little tab off the bumper, and the exterior trim bezel that slides in the bumper. The foglights come with install directions and the install is very straight forward. I dont have many pictures from install but here they are.
I need some better pictures, but they came out looking great! They go very well with the shape of the bumper (better than stock in my opinion) and provide a nice light output. The lights were wrapped with a 3M clear film to protect the plastic lenses from rock chips and sun damage. All the hardware was included with the kit and I added antiseize to prevent any chance of bolts starting to rust. Next was to wait until night time and test them out.
  • Like
Reactions: debrucer
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
Well, as with all projects I seem to get into with this car it spiraled out of control really quick. There has been a small bit of rust that I have noticed creeping on the underside of the hatch around the trim, it has been bugging me all year, so naturally wanting to fix the problem before it gets too bad to repair I pulled the hatch trim. In the process to get the side pieces off I sadly had to mangle the side pieces on the hatch glass to get them off as they were tar sealed in at the factory with the glass.
As I had done this I quickly realized that a big decision had come upon me. I ordered brand new hatch trim, and as I want the hatch painted before the trim Is on i only plan on painting the hatch once. This lead me to a dilemma, with the hatch being painted, it needed to be painted whatever color I want the car to be for the rest of my life. This lead to days of contemplation on what to do, repainting superwhite means it would only have to be the hatch resprayed, but it would be superwhite forever. Changing colors meant this would be the prime time to get the whole car resprayed. So after many days of thinking, I finally decided what do to. And to work i went stripping the car.
  • Like
Reactions: debrucer
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
Well, it has been a while since the last update, but I was putting in quite a bit of work getting the car ready for paint. I stripped it to find that there was a bit of rust hiding (more than I had hoped for) but nothing too terrible. I went to treating all of the rust that I could myself, which included a lot under the windshield and hatch glass, some in the channel on the front targa seal, and a bit of body rot. I decided to leave the heavy stuff to the body shop when I dropped it off.
As you can see, all the rust that I decide to treat myself I first wire wheeled the area down to bare metal, I then applied liquid rust converter.
I also took this time to relocate the battery but I'll have to get pictures of that when the car is back from paint.
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
The big day finally came though! It was time to drop it off for paint! April 4th I dropped it off for paint. The body is going to be staying stock with some cool authentic aero pieces that the average person probably wont even notice. (PS, first time I've ever trailered the car, and it drove itself on there. 1jz life)
Now I just wait anxiously for the call to come pick it up!
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
Even though the car is at paint, I still have parts trickling in awaiting the return of the car. I got all these this previous weekend.
A practically brand new supra badge and clip from Puerto Rico.
BTI dual can gauge with led shift light (I have a clever idea on the shift light)
Got the quarter glass re tinted in 20% ceramic tint since they're the hardest to retint when the car is back together.
And I also acquired this beauty! It needs a bit of elbow grease to be perfect, but with this piece I'm pretty certain i'm starting to be near, if not at 99% on having as close to a factory "Jdm" spec usdm a70 as you can have. Will update as more parts show up. Have a really cool one coming.
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,596
Location
Shakopee, Minnesota
Couple of months late on this,
but come on!
I drive but not like in my younger years. I take my time, see something interesting and pull over. Gas refills take a lot longer. 6 hours, break that out to two days. 3 hours per day :D
  • Like
Reactions: debrucer
Clip
The Magnificent Seven
Authorized Seller
Joined
Oct 16, 2005
Messages
2,913
Location
North Carolina
I really gotta say thanks for that picture of the BTI gauge. Saw that and was scratching my head til I looked it up. Now I NEED one. It solves the problem of what gauges and where to put them!
You're doing some great work, looking forward to seeing the car after paint.
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
The car is now back together. Been busy with work and enjoying the car after having it apart for months, hopefully tomorrow I can sit down and spend a while catching the build thread up. Lots of money and time have been spent since the last time I posted in April.
  • Like
Reactions: XofXtimeX
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
Ok, time to give a big update, before paint I found some rust lurking in the shadows that had not yet become visible, but I wanted to stop it before it had a chance to start, since afterall, the whole purpose the paint job started was to fix a spot of rust. I talked with the guy who was going to be doing the work and decided that I was going to let him do some of the rust, and on the other I was going to handle it myself, but I wanted to keep the car as original sheetmetal wise as I possibly could. So to cutting I went, these areas I found are all documented common rust areas on the a70, and with them being 30 year old cars you'd be hard pressed to find one without and rust in these spots.
Both sides had rust on the inner seam in front of the rear wheel starting
The passenger side had some rust coming through in this seam
This seam on the driver side had the seam rusting on the inner wheel well to quarter skin, and up the inside of the removed area, so I removed the area, wirewheeled down to bare metal and applied rust converter. Then I gave the removed metal back for him to reinstall when he was operating on the other affected areas.
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
While it was at paint I got to work on prepping the hidden body parts for going back onto a shiny new car when it returned from paint. Cant have rusty bumpers when I've gone this deep already! So I drug them out and got to work.
As you can see the pictures make them look better than they were, but with 30 years of aging and weathering, they were all pretty covered in surface rust. I wire wheeled and wire brushed all the loose rust away, covered the pieces in rust converter throughout, then went back and installed POR15 on all 3 pieces for a super durable and very pretty finish. After all was said and done they looked like this.
All this time I was hoarding all the new toyota parts I could get my hands on for reassembly and buying some old pieces from japan.
  • Like
Reactions: Piratetip
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
Also while waiting for the car to return from paint I was surfing the yahoo japan auctions and bought a 4.10 torsen that was claimed to be blown up, I figured it was worth it to take the chance. A few weeks later it arrived, and when I unboxed it it wouldnt turn by hand, I decided if it was indeed blown up it wouldnt hurt to try turning it with a ratchet. A bit of force and it broke loose! So now I knew I at least had a turning differential, but it felt to have a bad bearing. I was already planning at least changing seals, but now I was in for a full rebuild. After messaging piratetip and verifying all the diffs shared the same bearings and seals I ordered all new toyota bearings and seals, along with a weir solid pinion sleeve. Upon disassembling the differential I found that it seems to have been sitting nose down in water, causing it to rust the pinion bearing, but otherwise the differential appeared to be in great condition. I disassembled so that I could clean up the housing while I waited for parts.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,356
Location
MKE, WI
I've fixed multiple diffs with internal moisture damage to the bearings and R&P. (Etches the metal)
Pretty easy fix as the cast iron housing does not care.
This diff is the one with the rare longer side shafts right?
