Oil pump guide bushing
Falcon148
Authorized Seller
Joined
Apr 26, 2008
Messages
29
Likes
Location
Dallas,Ga
#3
Please read what I wrote, the one you pointed out is for the oil pump DRIVESHAFT BEARING.
What I am asking for now is the oil pump GUIDE BUSHING.
It's the bushing that the top of the oil pump goes into. The top of the bushing fits into a hole into the block.
Enraged
A HG job took HOW long??
Authorized Seller
Contributor
Joined
Messages
1,894
Likes
9
Location
Victoria, BC, Canada
#5
I love reading Gordons threads, so many great ideas. I just bought an oil pump spring shim from him, so he is still making parts for people, contact him there or on Supraforums, his username is sixpack
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
1,344
Likes
Location
MKE, WI
#6
Yep the parts he used to make that needle bearing work are quite simple.
Its a dang near perfect solution, substitute a bushing for a needle bearing.
Similar to what Andrew has done for the oil pump retainer on the front of the engine.
Required only :
-Drilling out the center of the cap screw
-Drilling and tapping the pump shaft
-Machine a seat for the screw to sit flush
Talk about an easy solution, I could duplicate that very easily here with the lathe.
If I ever need to replace this part again.
And cheap!
