Oil before start
Enraged
A HG job took HOW long??
Authorized Seller
Contributor
Joined
Messages
2,062
Location
Victoria, BC, Canada
disconnect the injectors, pull the spark plugs, then crank it over until you see the oil pressure gauge move.
GC89
BoostRodeo
Authorized Seller
Contributor
Joined
Jun 13, 2007
Messages
1,045
Location
Spokane, WA
This ^ or remove the timing cover and timing belt and spin the oil pump independently with a drill then hook everything back up.
Authorized Seller
Joined
Apr 17, 2007
Messages
12,762
Location
Tokyo,jp
Just pull the efi dude and crank till you see oil pressure. 30sec cranking. 30sec cool down for starter. Repeat. Cranking rpm with everything hooked up is fine. Will take 1-2 cycles.
  • Like
Reactions: loc182 and Enraged
Enraged
Authorized Seller
Contributor
Joined
Messages
2,062
Location
I forgot about the EFI fuse, ya do that. Pulling the plugs removes load that the starter has to turn, but it shouldn't really matter.
