Nozzle Sub-Assembly, Washer
Asterix
Lurker of Power
Authorized Seller
Joined
Messages
502
Location
Vienna, VA
So, the pre-89 nozzles are discontinued, but the 89+ ones are not. My '88 needs a new one, and I may as well replace both. Rather than risking $40-ish buying them and them not fitting, I thought I'd ask here.
Can anyone supply a good photo of a 89+ nozzle so I can compare, especially the underside? A photo of the hole in the hood would also be nice. As long as the 89+ nozzle fits in my hole I can easily adjust the hoses if I need to.
Thanks!
Asterix
Lurker of Power
Authorized Seller
Joined
Messages
502
Location
Vienna, VA
I'm a gonna splurge and get the 89+ nozzles. The low-res line drawings in the EPC look the same for both. Worst that happens is I'm out the 20% restocking fee and return shipping.
I'll post a photo when they arrive, in case it helps someone else.
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
120
Location
Lexington, Ky
99% sure the hoods are stamped the same, only nozzle design and shape are different from pre89 to 89+
  • Like
Reactions: Asterix
Asterix
Lurker of Power
Authorized Seller
Joined
Messages
502
Location
Vienna, VA
Nope. 89+ nozzles require a larger hole. 89+ is on the right. Hose barbs are the same.
Since my hood has no paint on it right now, I'll probably have the shop make the holes larger and use the new ones. It would be very nice to have new plastic there, as the 32 year old plastic is getting kinda crumbly.
  • Like
Reactions: debrucer
debrucer
It's about the journey
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
297
Location
San Diego, California, United States
I think I'd try AutoZone for something universal. I can almost picture them on a rack somewhere.
Asterix
Lurker of Power
Authorized Seller
Joined
Messages
502
Location
Vienna, VA
From some searching it very much looks like Toyota went to a commodity nozzle for the 89+ models. Many Toyotas well into the 2000s and other cars (like Chrysler) use the later version. That would be why it's still available.
Dorman makes one with a 0.24" threaded shaft that may fit.
I found one on fleaBay. If it looks decent, I'll use it. It's certainly possible to carefully enlarge the holes at any time in the future.
  • Like
Reactions: debrucer
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
1,812
Location
MKE, WI
I recall in the past someone else looked into fitting the newer nozzles to the old hood.
Ran into the same issue as you where the hole needed to be enlarged.
I thought there was another newer model washer that had a better fan pattern vs. the 2 hole stream.
Asterix
Lurker of Power
Authorized Seller
Joined
Messages
502
Location
Vienna, VA
Clearly I should've searched more before buying the wrong nozzles.
Yes, there are upgrades to the new ones. I've never had really any issue with the streams, but I've never tried crossing them.
