New source of Torsen T2 LSD's
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
2,410
Location
MKE, WI
Ah there it is.
The inside surface finish I thought would give away it's manufacturing method.
You were correct, these covers were either an afterthought or they knew only a small number were to be made.
That surface finish to me looks exactly like lost foam sand casting.
Which also explains the bumpy surface finish you said you were having to clean up on the outside as well.
Much cheaper to manufacture than how the normal covers are made.
Al die casting.
In that closeup photo you can still see the styrofoam shape, looks exactly like packing material you would find around a TV or something in a box.
Hybrid
Supramania Regular
Authorized Seller
Joined
Jan 3, 2008
Messages
Location
Australia
Awesome info Nick!. Yeah funny you say the last bit....let me grab another snippet I think you will like :)
These circles with lines are everywhere throughout the casting.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,410
Location
MKE, WI
Yeah those markings are on the foam as well.
You have seen those before on styrofoam, I guarantee it.
I took a picture of a piece of foam I have lying around here.
Has circles with dots not lines but same idea.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,410
Location
MKE, WI
Also for reference this is what die casting looks like on the inside of the normal covers.
Very smooth, but you can see wrinkles and grain boundaries on the surface.
Tell take signs.
Hybrid
Supramania Regular
Authorized Seller
Joined
Jan 3, 2008
Messages
Location
Australia
You bet :). But yeah very interesting indeed I must say.
Hybrid
Supramania Regular
Authorized Seller
Joined
Jan 3, 2008
Messages
Location
Australia
Have also clear coated the decal under. It sits above the drain plug on the underside of the fin stock wise.
Hybrid
Supramania Regular
Authorized Seller
Joined
Jan 3, 2008
Messages
Location
Australia
Note modified fins at bottom of pic. Was best I could do, it's hidden inside subframe also.
3p141592654
90T
Authorized Seller
Contributor
Joined
Oct 11, 2005
Messages
4,242
Location
Thousand Oaks, CA
Is the main benefit of this cover the extra protruding cooling fins or is there something more? I recall some sort of cooling contraption that stuck out of the differential on euro spec models. Is this related to that?
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,410
Location
MKE, WI
It's additional cooling yeah.
The vertical heat pipe on the cast iron housing was part of that as well in EU.
But just the rear cover change would help a little
Hybrid
Supramania Regular
Authorized Seller
Joined
Jan 3, 2008
Messages
Location
Australia
There were also air ducts/deflectors. One bolted to the top of the subframe, and there was another under but don't have a pic of that. Both are unfortunately NLA. You can see the top one here.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,410
Location
MKE, WI
Ah yup.
Nice crusty diff you got there. :D
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,410
Location
MKE, WI
Finishing up another T2 Torsen diff build. :D
Jeff Lange
Administrator
Administrator
Authorized Seller
Joined
Mar 29, 2005
Messages
5,076
Location
Edmonton, Canada
Haven't driven one in an A70 yet, but I've driven with them in the Lexus IS, Scion FR-S, and my 1993 Previa ice-racing van and was always extremely happy with the smooth transition and grip provided by them. My favourite differential for a mix of street and track driving for sure.
(Just don't lift a wheel, or you'll have a bad time)
Jeff
  • Like
Reactions: Piratetip
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,410
Location
MKE, WI
Jeff
Oh forgot to ask, in the Previa were you using the same Torsen as the MKII supra guys?
The 7.5" Truetrac?
Funkycheeze
Grease Monkey
Authorized Seller
Joined
Jul 3, 2009
Messages
167
Location
Calgary
T2 feels great in my 2JZGT powered A60 Celica Supra with an 8" rear end (from a GX71 but same internals as a mk3). It locks up more smoothly and has a higher torque bias than the old truetrac I had in a 7.5". Just remember to extend the side shafts as per my previous post or you will damage the seals, case and dust shields! The 6mm washer stack works great as past where the retaining clip engages there isn't any spline inside the T2 unit so the extension just needs to be small enough to fit inside the splines.
  • Like
Reactions: Jeff Lange
