New Heater Valve Replacement Options???
plaaya69
87T Supra
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,275
Likes
51
Location
Lake County, IL
#1
I am thinking about getting a working r12 a/c system back in the Supra so I would like to retain a opening and closing heater valve. Currently I have a 90 degree brass sharkbite fitting that works good to keep the coolant flowing but does anyone have any aftermarket replacement options besides a used oem brittle plastic heater valve?
I might be looking into this metal one since it retains a vacuum port and seems to be the same 5/8" heater hose size:
FOUR SEASONS 74604-
https://www.rockauto.com/en/partsearch/?partnum=74604
plaaya69
87T Supra
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,275
Likes
51
Location
Lake County, IL
#4
I do like the oem design but in my 87 Supra that is the only time I was left stranded due to the brittle plastic all falling apart. I know as time goes on and mileage goes up it will just be a matter of time before a used one cracks again.
I have also been suggested this one from another Supra owner which comes from a late 90's Camry. They said you need to use the arm linkage from a Supra.
FOUR SEASONS 74850:
https://www.rockauto.com/en/partsearch/?partnum=74850
3p141592654
90T
Authorized Seller
Contributor
Joined
Oct 11, 2005
Messages
3,999
Likes
Location
Thousand Oaks, CA
#5
Likes: plaaya69
plaaya69
87T Supra
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,275
Likes
51
Location
Lake County, IL
#6
The metal one you show I think has the polarity wrong on the vacuum actuation, but you can fix that by rerouting the hoses on the solenoid.
Jetjock cross referenced it to a late 90s Geo Prizm or 92-01 Corolla. Here is his post.
http://www.supramania.com/forum/threads/what-is-this.69435/post-987930
Here's one on ebay
https://www.ebay.com/itm/For-1992-2002-Toyota-Corolla-Heater-Valve-64978HH-1996-1997-1993-1994-1995-1998/392125763455?epid=20023824644&hash=item5b4c844f7f:g:OggAAOSwcTlbn5Md&fits=Year:2001|Model:Corolla|Make:Toyota
Interesting, thanks 3p.
