(I copied this from my intro so i can kinda keep track on where I am).
My intention is to keep this MK3 pretty much stock, considering the low mileage and very good over all condition.
Projects Done:
New front speakers.
Clean, adjust and lube windows and lock mechanisms.
New E brake boot (getting tired of blue stains on pants)
Looks like the battery when nuclear at some point. Clean, neutralize rust and paint (paint may have to wait for warmer weather or a better garage heater).
Hopefully before weather gets too cold:
New HKS exhaust.
Winter To Do:
Paint-less dent removal.
All new sport roof seals. (see below)
Remove both front seats and fix leather.
New rear hatch lifts and rear speakers.
New Plugs and wires.
Inspect / replace ragged out vacuum and coolant hoses.
Repair cracked radiator fan shroud. Not strong enough to support body weight when working on engine.
Need to be sorted:
Suspension: bushings, bearing, end links, probably everything.
Fix starting issue, if not corrected with new hoses and ignition stuff.
Verify fuel pump pressures. (based on past owners comments about some “bone-head” he had install the last one)
The list goes on.
My OCD tendencies kick in, and I can’t stop.
I have a local support group, but they are all junkies too!
Kevin
