mkiv TT wheel lug nuts
supratkfy
Authorized Seller
Joined
Messages
78
Likes
for those of you running TT wheels.....what lug nuts are u guys using? i kno mkiii stock ones work but i don't have any..the ones that i get from kragen's ar the acron style ones and i don't think they work....they sit in too far...i might need the ones with washer? anyone know of a place online? or where i can get a set...i'm using the acorn ones for now on the TT and don't really trust it
supratkfy
Authorized Seller
Joined
Messages
78
Likes
yea i kno but i don't have any stock ones...don't recall how it looks either
supratkfy
Authorized Seller
Joined
Messages
78
Likes
i never had the stock ones....the guy who i bought the car used a different one already....
for now i went to local kragen's and got the mag wheels one with washer....the fronts are ok but i think the rears might not be...it seems like the washer is spinning and the lug is not tight against the wheel..hmm anyone else
supratkfy
Authorized Seller
Joined
Messages
78
Likes
ok after changing it to those...the car makes a lot of noise when the wheel is rolling......it could be the lugs but i got to check tomorrow.......it sounds really bad...but the lugs are still tight. also when i drovev on the freeway it seemed like the wheel was unbalanced but before i changed to the mag style lugs with washer and had the acorn style ones on it was fine....so i'm not sure is it the lug nuts or something on my suspension just broke.....because i just changed the lugs when all this started to sound
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Authorized Seller
Contributor
Joined
Messages
3,144
Likes
Location
Hayward , Ca
#7
Man make sure those lug nuts are of the right thread and depth. My MkIII had the washer kind lug nuts as well, but were the stock ones.
Could the noise be from the tupe of tyre you are running? Some tires make horrible road noise man..
SnowMongoose
Authorized Seller
Joined
May 20, 2005
Messages
150
Likes
Location
Bellingham, WA
#8
hijack!
anyone know where to get lug nuts, other than toyota?
toyota want 9 bucks a pop, and I havent been able to find anything cheaper anywhere...
Ideally I wouldnt buy a whole set, I only need 5
:p
supratkfy
Authorized Seller
Joined
Messages
78
Likes
the ones from kragen are right thread but not depth.....those are the ones with a washer but the shank is too short....i got 5 from toyota to see how it is and those are different...its more of an open ended shank type with the washer...that is the noise because when i jacked the car up...the tires were a bit loose..but lugs were tight...so i have to go with toyota ones...heard its only dealer item for those lugs...unless someone has a set...they wanna sell
suprastanger507mgte
Authorized Seller
Contributor
Joined
Messages
3,144
Likes
Location
Hayward , Ca
#10
SnowMongoose said:
hijack!
:p
If you can find a MkIII in the junkyard, you can pull the lug nuts off it.
supratkfy
Authorized Seller
Joined
Messages
78
Likes
^^^yea the MKIV TT lugs fits the MKIII because they are same thread...12 x 1.5....i had to buy a set from toyota since i don't have time to go to a junkyard to get it....$4 a piece...the MKIV lugs are actually a dealer item only i think...its an open end with a washer, shank..
supratkfy
Authorized Seller
Joined
Messages
78
Likes
u should elmhurst toyota....not sure are you on supraforums but elmhurst has a part ordering there and have a phone number you can call....he quoted me $4.65 it hink for one....not bad compared to $9...local toyota was able to give it to me for $5 and have it by the next day...so i just had to get it so i can drive my car
