Mk3 supra 2jzget knocking after rebuild
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
1,979
Location
MKE, WI
No idea.
It's hard to follow now.
Was never the engine to begin with, it passed all the litmus tests there.
All the symptoms when the noise was happening pointed away from the engine being the problem according to the OP diagnosis.
Trans in gear, out of gear, clutch in, clutch out ect....
At this point need an experienced tech with a stethoscope up on a lift.
Shouldn't take long to narrow it down to a component.
  • Like
Reactions: debrucer
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
178
Location
Lexington, Ky
Yeah, as said above it has reached about the limit of anyone being able to help unless they're there with the car to diagnose in person sadly.
  • Like
Reactions: debrucer
mk3turbo
Authorized Seller
Joined
Sep 5, 2008
Messages
198
Location
michigan
Ok got the pistons and rods out, looks like piston slap is my problem but not 100% sure. Not sure why its slapping when its already warm and comes on when driving but revving in neutral has no knocking. Still holds good compression 200psi-210psi. Gotta take my block to machine shop to have them check the bores, check the clearance From piston to wall.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
1,979
Location
MKE, WI
Yup. That makes no sense.
Piston slap goes away when the engine is warmed up.
Somebody screwed up clearancing the cylinder bores for those pistons bad if that is truly piston slap.
Bore gauge the cylinders and measure the pistons. Check against CP specs, see how far off they are.
