Loud, single click and no start.
Joined
Aug 12, 2010
Messages
347
Location
P.G. County, Maryland
I just tried to jummp my car. It's supposed to get below freezing tonight and i wanted to let her idle for a while to warm up sonce i haven't in a while. My battery is gone, i loaned it to a friend because his died and i can't use my car anyways. I put the old one in just to complete the curcuit and tried to jump start it. When i plug in the battery my interior lighs come on and such, just like normal. However, when i turn the key, i hear one very loud CLICK from fight behing the dash. I had my brother try so i could listed. It seems to be coming from right behind the motor, like starter position. After the noise, i have no more power. Lights wont come on, can't try again with the key. I unplugged the battery and waited a few seconds, then plugged it back in, but it wont start, and my lights arent back on. I checked the fusible links and fuses in the bay, and under the driver side kick panel. what am i looking at here? Starter solenoid, fuse, starter, starter motor? Its really cold here, and has been for a few days, if that means anything. C'mon, monkeys. I know you know. -.- (91' turbo auto.)
mkiiichip
Authorized Seller
Joined
Sep 10, 2007
Messages
1,434
Location
WI
Replace the contacts for the solenoid, in the starter, or replace the starter.
A strong battery may help it last a little longer, but its something that happens to all starters of that style.
Blackdawg
Taco Soup..my rides
Authorized Seller
Joined
Oct 12, 2010
Messages
258
Location
Wyoming
Its not battery not the starter. This just happened to me on my tacoma and a friends bronc. I know it wasnt the starter on my truck cuz i had just put a new one in a year ago.
All the problem was was no voltage, was putting out like 2.1v lol
new battery is needed :)
Joined
Aug 12, 2010
Messages
347
Location
Thanks guys. BTW i just realized how ridiculous my spelling was the other night when i posted that, I sound like a retard. lol, Going outside now with a different battery to try it. If you're wrong... Oh, just hope you're not wrong...
NTRA08
TWINKY
Authorized Seller
Joined
Jun 10, 2008
Messages
530
Location
Conroe, Texas
This happened i both of my supras. It ended up being the blue wire on the starter having a bad connection.
CyFi6
Aliens.
Authorized Seller
Joined
Oct 11, 2007
Messages
2,972
Location
Phoenix
Lol, run a decent size jumper wire from the batter positive post down to the terminal on the starter with the brown connector/blue wire. Pull the connector out and touch your jumper to the spade thats on the starter. MAKE SURE you car is in park or nuetral depending on if its manual or automatic or its going to run you over.
Joined
Aug 12, 2010
Messages
347
Location
That is... So comforting. "Alrighty babe, be easy now, i'm is just going to put this one little wire right over here and its going to make you all bet- MOTHER OF GOD, MY LEGS!"
---------- Post added at 01:52 PM ---------- Previous post was at 01:49 PM ----------
Basically I'm just running a wire from my battery to my starter, right Mr. Rocket Scientist?
JDMMA70
Well-Known Member
Authorized Seller
Joined
Dec 4, 2006
Messages
2,682
Location
Houston
take a stick and try tapping the starter while someone cranks it. If it starts replace the contacts in the starter.
super.secret.supra.club
Authorized Seller
Contributor
Joined
Mar 22, 2007
Messages
1,304
Location
San Diego, CA
...I might have just slipped it on...... ... maybe...
ide tighten it. it happens to me all the time . i dont know why everybody is saying the starter is the problem. the OP clearly stated that the whole car has no power what so ever, so, why would the starter be the culprit?
one person says stater and everybody jumps on the band wagon.
who cares what what i think though. enough of my damn rants. GL OP
Authorized Seller
Joined
Apr 17, 2007
Messages
12,768
Location
Tokyo,jp
Sounds like you put a junk battery in. Put a good battery in and start it if not tap on the starter solenoid and see if it starts. Usually clicks are 1 of 2, either bad battery or bad starter.
jetjock
creepy-ass cracka
Authorized Seller
Contributor
Joined
Jul 11, 2005
Messages
9,439
Location
Depending on what the current (a little electrical pun there) symptom is super secret's point has merit. If there's no power at all check the battery connections.
Which reminds me of an old mechanic's trick: crank the engine with the headlights on. If they dim the battery connections are solid. If they go out one (or both) of the connections are loose. This test requires a good battery and starter though.
Joined
Aug 12, 2010
Messages
347
Location
I feel there is a common misconception here. I guarentee you that a bad battery is NOT to blame, because i was jump starting my car. start other car, connect cables. Interior lights come on, warning blip sounds telling me my doors are open, ring around ignition comes on. Turn key and dash comes on. Turn all the way to START, and i get one, loud, electrical sounding CLACK. It sounds like a wire shorting, or a breaker tripping in your house. After this, all electrical components turn off, including door lights and... well... everything. It's like i dont even have a battery in my car, even my battery is attatched to another car thats RUNNING. after that i can't try again, i get no power. I only tried it once after that, but i had to disconnect the jumpers and wait a few minutes, then miraculously i re connected the cables and the same thing happened. CLACK, no power. I look at my phone and see the time, realize its freezing outside, say fuck it and go inside. lol
