Looking for coilovers
kueves87
Authorized Seller
Joined
Oct 18, 2009
Messages
34
Likes
Location
tucson
#1
Is there a really huge difference between the Teinstreet advance and the flex z? I'd like the car to be relatively comfy on the street and still be able to take it to a track every once in a while, just couldn't really tell the difference between the two besides price. I'm definitely willing to spend the money if people have had good experiences with the flex. thanks!
plaaya69
87T Supra
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,426
Likes
96
Location
Lake County, IL
#2
I have the Flex Z version and I like them a lot. With all the damping force adjustments you can fine tune them to your liking and you do notice a difference from feel every bump in the road stiff to old 70's Cadillac bouncing down the road soft with adjustments in-between. I keep mine 5 clicks away from the stiffest setting and it handles great for everyday driving. I also liked the ride height setting it came with from Tein so I did not touch that.
I will say with these coilovers, I originally installed them on a original factory suspension parts but once I did the ST sway-bars and adjustable end links it handled better, then the rear battle version arms became even better. Just recently the last thing was the 4 rear pressed in lower bushings in each spindle with a alignment done and it is super responsive and feels solid now.
Likes: YotedmyMA70
kueves87
Authorized Seller
Joined
Oct 18, 2009
Messages
34
Likes
Location
tucson
#3
Awesome thanks! I figured they were gonna be the way to go, just needed some reassurance
BorHor
2JZ-GZE
Authorized Seller
Contributor
Joined
Jan 10, 2006
Messages
6,195
Likes
Location
San Jose, CA
#4
I installed a set of flex z on a 300zx and did not like them at all. The dampening was just not good at all. I been through a lot of coilovers over the years and the lowest end I go on my basic street car is BC.
Likes: kueves87
twin2turbo
Authorized Seller
Joined
Apr 1, 2010
Messages
73
Likes
8
Location
Mill Creek, Wa
#5
I'd highly recommend Fortune Auto. Their 500 series has good valving and spring rates for a street setup, which is what most people do. The 510s have insane valving for shock body that isn't 2 way, which allows amazing adjust ability, the ability to hit curbing on a track and high speeds and have valve blowoff. Also with such a wide valve range you can have a huge swing of available spring rates with out a re valve. I run 510s on my Time Attack car, but they are 3 times the cost most entry level coils
Teins are okay for an entry level coilover but dont expect greatness. It all depends are what your price point is and use. You could easily spend up to 10k on a good set of coilovers. Getting the correct valving and spring rate is extremely overlooked and the most important
kueves87
Authorized Seller
Joined
Oct 18, 2009
Messages
34
Likes
Location
tucson
#7
Oof as of right now 1200 is out of my price range, considering this will mostly be a street car, with some light track and drag down the road. i was also looking into BC and megan racing coilovers so theres definitely no shortage of options out there. Thanks for the suggestions guys I definitely wont rule anything out.
JDMMA70
Authorized Seller
Joined
Dec 4, 2006
Messages
2,667
Likes
19
Location
Houston
#8
Im running a set of Tein Flex Z on my Supra. I am satisfied with them coming from my old Tokico Illumina II and H&R spring setup. They passed the old man test (having my 72 year old father ride in the car with me). I am satisfied with the 16 way dampening.
Likes: kueves87
kueves87
Authorized Seller
Joined
Oct 18, 2009
Messages
34
Likes
Location
tucson
#9
Awesome, they're definitely top contenders right now... depending on what happens over the next couple months as far as side jobs and cash flow go i may step up to some bc or fortune auto cuz i like the rebuild ability, ill keep you all in the loop on what i end up getting . thanks again guys!!!
Enraged
A HG job took HOW long??
Authorized Seller
Contributor
Joined
Messages
1,977
Likes
26
Location
Victoria, BC, Canada
#10
if you get Teins, you have the option of adding the EDFC whenever you want, so you can get back the remote adjustability of the stock setup.
kueves87
Authorized Seller
Joined
Oct 18, 2009
Messages
34
Likes
Location
tucson
#12
Oh damn and they’ll even adjust the damping force to whatever you want too.... seems like a pretty sweet deal for 750....
loc182
Seven Empowered!
Authorized Seller
Joined
Jul 3, 2013
Messages
328
Likes
24
Location
Bothell, Washington
#13
Sorry to thread jack, but are you saying that the EDFC can be installed so that the TEMS system can control its actuators?
Enraged
Authorized Seller
Contributor
Joined
Messages
1,977
Likes
26
Location
#14
No, you get a system that is similar to TEMS in principle but better in execution. More levels of adjustment, and I think there is now a GPS enabled version too.
loc182
Seven Empowered!
Authorized Seller
Joined
Jul 3, 2013
Messages
328
Likes
24
Location
Bothell, Washington
#15
Oh, ok, that is what I thought, but I was really hoping I was wrong :p
It would be amazing if Tein made a EDFC kit that allowed the use of the existing wiring from TEMS!
