How did this happen?
Koenigturbo
Authorized Seller
Joined
Oct 4, 2006
Messages
1,505
Location
Oxnard CA
You Tube:: I watched a mkiii Supra walk around video, when he turns the key to the "on" position, the tach pegs to eight or nine grand and after the car starts the tach goes normal, just like Corvettes and Lexus. How did he do this?,... Thanks!!!
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
2,308
Location
MKE, WI
Probably standalone control strategy.
Hope the engine is using some quality oil with strong film strength.
That's a good way to wear out the rotating assembly before oil pressure is developed.
Unless of course they are also using an oil accumulator before engine start.
Then it does not matter.
Falls into the category of BMW " burble exhaust tune"
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,308
Location
MKE, WI
You are probably correct now that I read through it again. Doh!
My bad.
Abe's 1987
Si vis pacem, para bellum
Authorized Seller
Joined
Sep 5, 2017
Messages
1,052
Location
Houston,TX
its like those aftermarket guages that spike up then down on car power up!
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,308
Location
MKE, WI
Probably running a standalone feeding the signal to the tach.
Someone did it here with the AEM.
You could do it with a small additional circut as well, handmade that does a sweep on startup.
But probably not the case.
