Help with finding a gasket
debrucer
It's about the journey
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
286
Location
San Diego, California, United States
11432E-Washer-Gasket.PNG It's more like a washer than a gasket, but it is made of a composite material... it's fiber, but also lightly magnetic. The part number is 11401-11432E as seen on this drawing from Cygnus. I've been to two dealers and they've gone through the supersessions, alternately saying no longer available and they will be here tomorrow. Nothing. I've also been to both of my favorite hardware stores. Nothing :(.
Anybody have stock or suggestions? My engine and transmission are sitting there ready to go... for lack of a couple of gaskets.
Thank you all.
David
plaaya69
86.5 Turbo Converted Supra
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,498
Location
Lake County, IL
Are you talking about the freeze plugs in the back? If so a machine shop should be able to help you get the right size.
  • Like
Reactions: debrucer
debrucer
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
286
Location
@Piratetip I'm not sure which numbers were ultimately searched. Several conversions were made, and several wrong parts brought to the counter. That's why I started out here today with the Cygnus numbers. The Cygnus catalog lists four possible engines, and this gasket is only used on the early NATO model (which I presume is North America Toyota). I got one of the plugs, and I saved one of the gaskets, was going to provide pictures but the system rejected every size file I tried to use.
Thanks for the URL. That looks like the next logical move, but first, I will try to nail down the right part number.
These plugs are screwed in and have a hex-head. The other three engine models have them tapered and the block is tapered. In this model they are flat and the block is flat to match. I wouldn't call them freeze plugs, as if they froze and reacted it would ruin the block. @plaaya69 the plugs in question are on the other side of the engine and behind and/or below the starter motor.
Great info here, but don't stop if you have more ideas :) I will research the overseas solution, but, hey, maybe someone has a source closer to home?
Authorized Seller
Joined
Apr 17, 2007
Messages
12,762
Location
Tokyo,jp
If it’s tapped then just use a copper or alum crush washer. It doesn’t have to be fiber.
The crush washers will last long as well
  • Like
Reactions: debrucer
plaaya69
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,498
Location
Lake County, IL
Interesting that they used to use 2 Hex bolts:
https://www.google.com/search?q=7mge+block&safe=off&source=lnms&tbm=isch&sa=X&ved=0ahUKEwimt5yW48nhAhUGQ60KHZG0ALQQ_AUIDygC&biw=1600&bih=767#imgrc=9r9trD1JdlzRBM:
I would still suggest a local machine shop for the right size crush washer and they should point you in the right direction. Even Napa should have a drawer full of copper crush washers on hand or have them pull out their big catalog book they should carry and they should be able to get you the right size you need.
  • Like
Reactions: debrucer
debrucer
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
286
Location
Here's a small image (118x119)... thought I'd try again :)
Saturday: Sometimes I can upload, sometimes I can't. Here is a full-sized version of the smaller image that was here earlier :)
That's the plug and gasket to the right... Have one gasket, believe I have two plugs but can't find other at the moment.
This early block, pointed out by pictures IJ posted (which are gone today) is the reason that I dropped my HP expectation to 500 rw.
I have the early block and the early crank. Oh well.
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
1,789
Location
MKE, WI
Can't view the image you just posted, too small.
Upload the full resolution image to imgbb.com.
Select BBCode FULL or Thumbnail, copy that link here to your message.
Here is an example I just uploaded there.
This is the code for thumbnail for this specific photo:
If you don't want to try and get the part overseas, plaaya69's suggestion is probably the best bet.
Find you local hardware store or NAPA that has large selections (assortments) of crush washers.
Just match it up to whatever they have for crush washers, Aluminum, Copper, Fiber they should all work.
Edit: Your photo is working now.
That gasket is quite large 41mm.
  • Like
Reactions: debrucer
debrucer
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
286
Location
debrucer
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
286
Location
A much larger version of the photo is there now.
In the old days we used PhotoBucket free accounts, spam and all. I deleted both accounts after getting to the point where I wasn't posting here. I realize that storage costs and all that, but sometimes I can upload sometimes I can't. I replaced that image you couldn't read with a larger one... the same size that would not upload earlier :) Go figure.
I've been to Marshall's Hardware, and they usually have everything. I've also been to ACE, Home Depot and Lowe's. No luck. Two dealers, and at least one $60 invoice for a handful of pieces, the plug in the picture about over 14 bucks :( The owner of the local machine shop is a p****, so I just don't go there.
Update: Chris Rhodes found me here and invited me to join his FB page: San Diego Supras. He also posted my request there, so I will wait a few days before trying @Piratetip 's suggestion.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
1,789
Location
MKE, WI
Yeah same here. Used to use Photobucket as well before they mucked it all up.
Check NAPA, one with a lot of those universal parts selections.
Or some other gasket equivalent should work.
Coolant system only sees a Max of 14psi or so.
Lowe's and HomeDepot don't have jack, I was just there looking for a small crush washer. They have nothing like that.
  • Like
Reactions: debrucer
debrucer
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
286
Location
debrucer
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
286
Location
I did a lightning fast search and here is what I came u with
https://www.parker.com/Literature/Praedifa/Catalogs/Catalog_CompSealingWashers_PTD3358-EN.pdf
it is a PDF. Just look for the OD and ID to see what matches. They have a ton!
There sure have an assortment but nothing with the required dimensions. Interesting catalog & inventory for "five" different compression washers... great descriptions of the design and usage, including the various temperature ranges. Interesting. Thanks for trying :)
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
1,789
Location
MKE, WI
These 2 from the Parker catalog look just about dead on.
WZ 2543 V5170
WZ 2543 V5172
  • Like
Reactions: debrucer
debrucer
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
286
Location
WZ 2543 V5170
WZ 2543 V5172
I ruled out the WZ series based on the description of the washer. The WO series looks to me to be the correct one, and they don't have the same sizes in that series. The ones you mentioned are pretty darn close 1.4 mm off on the outer, and 1.11 off on the inner. The second number is the FKM rating for temperature. Thanks for double-checking my work :)
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
1,789
Location
MKE, WI
Why did you rule out WZ series washer?
Its self centering, has an overmolded/vulcanized NBR or FKM inner elasomer sealing ring.
Also those 2 part numbers have a burst pressure of 810 BAR!
These are interesting as the metal section is not designed to deform and seal.
The inner elastomer sealing ring does that.
It is a different sealing design than OEM, but would work IMO.
I would say they should work very well, as long as both sealing surfaces are clean and flat.
  • Like
Reactions: debrucer
debrucer
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
286
Location
<snip>
I forget why I ruled them out, but went back and re-visited the specs... and yes, they can be made to work.
I called Parker in Pennsylvania, I think, and after two calls they directly connected me with a branch/division or something that is located in San Diego. That guy deduced that this was a German product market catalog, and of course, I believe it came from an Australian based user recommendation. He agreed to make the request by email to someone in Germany, and since I only want two of each of two part numbers, he kept referring to "samples". It's been a few months now, communicating with this local guy at two week intervals... and the last two times, one-sidedly, leaving him voice mail.
If anyone from here in Germany, or perhaps Australia, can obtain me the following washers, I'd certainly appreciate it :)
From the Parker catalog:
2) WZ 2543 V5170 washer
2) WZ 2543 V5172 washer
debrucer
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
286
Location
Maybe try a different Parker distributor?
Sounds like you got someone that just does not care to help you.
Try these guys: https://www.zatkoff.com
I do believe you are correct :( The guy who was doing the legwork received an email in July and said nothing to me... and did not return at least two voice mail messages. Today he quoted the last email from Germany which said "because we have not sold these in a long time we consider them obsolete and will not be providing them in the future".
I searched the ZATKOFF site and found nothing. I contacted them through the form and they have already responded that they will get back to me as soon as they "get a quote". If they're contacting the same place, I'd expect the same answer. Obsolete.
I will make something and get on with it. It's time to put the engine in the car, and these are sort of under the exhaust manifold.
Thanks for all your help. I appreciate everyone's help and suggestions.
debrucer
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
286
Location
Jeff Lange
Administrator
Administrator
Authorized Seller
Joined
Mar 29, 2005
Messages
5,061
Location
Edmonton, Canada
1986-87 7M blocks used an M32 threaded bolt (90341-32070) with the gasket (part number 90430-32222, replaced by 90430-32002, now discontinued). For 1988+, they replaced it with a 30mm frost plug (96411-43000). It's not shown very clearly in the parts catalog.
My suggestion would be to order 90430-33133. Toyota used this plug in many applications and everything else that used 90430-32222 switched to using 90430-33133, which is still available from Toyota.
Another option from Toyota is 90430-32004.
That said, it sounds like you may have already sorted this out, so this post is more informational than anything.
EDIT: Another note for future part lookups, the numbers shown in the diagrams are rarely the actual part number. They're what Toyota calls PNC's (part name codes), they reference the type of part, which you then look up the actual part number. PNC 11401 is the block (part numbers are 11401-49585 and 11401-49576 for the 7M-GE and 7M-GTE respectively), PNC 11432E corresponds to part number 90430-32222.
Jeff
debrucer
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
286
Location
Jeff
Somewhere between April and recently I discovered how to drill down in the EPC (Electronic Parts Catalog), and the numbers found there are closer to actual, and yes, often superceded and/or discontinued. Presumably the two Toyota dealers that looked up the numbers for me caught any mistake I made in the numbers. Not sure why it wasn't a bit easier to find something as simple as a 32 mm washer :)
That's a great explanation. Thanks for making it clear. Yes. I've got my washers and can't find the darn hex wrench.
  • Like
Reactions: plaaya69
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
1,789
Location
MKE, WI
can you find a cheap bolt thats head will fit? Cheaper than buying a huge allen key or socket for a single job
Good advise here!
I have done this in the past.
Cut the head off the bolt and weld it to an old socket or something.
  • Like
Reactions: debrucer
debrucer
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
286
Location
Great ideas guys. I’m sure I’ve got the wrench. I took it off and was carrying with me for months. It’ll turn up, but if it doesn’t there are possibilities. Thanks.
debrucer
Authorized Seller
Contributor
Joined
Dec 11, 2006
Messages
286
Location
... right next to the receipt from NAPA for the washers, my hex socket :)
