Good day. I have a cressida 7mge engine. I replaced the fuel pump in the tank, but still no fuel in the lines. If n bridge the pump it runs. But as soon as you take bridge of i still dont get the pump running.
Need the vane in the air flow meter to be open (engine sucking air) for the pump to run.
You can take the air filter off and manually open the flapper with a stick. It should then cause the pump to turn on when the igntiion is on. Does it pass that test?
