Flywheel bolts, FPIG or Loctite
improved
Running!
Authorized Seller
Joined
Apr 4, 2005
Messages
195
Likes
Location
California
#1
Hey guys,
I'm installing my clutch and I'm re-installing the flywheel bolts. I can see that leaking is a possibility from the bolts.
Should I use FPIG or Loctite?
Thanks,
Matt-
JonoTurbo
Going for broke
Authorized Seller
Joined
Messages
670
Likes
Location
CT
#2
You don't want those bolts backing out for any reason, use Loctite. I've never had an issue with leaking. I would recommend against reusing flywheel bolts for the same reasons.
tlo86
Ninja Editor 'Since 05'
Authorized Seller
Contributor
Joined
Jul 24, 2005
Messages
3,914
Likes
Location
Colorado
#4
loctite w/ arp here
i wouldnt reuse old bolts personally
whatever you do be sure to clean all threads first :):)
RacerXJ220
Interdimensional
Authorized Seller
Contributor
Joined
Messages
1,504
Likes
Location
Abalama
#5
If there's leakage, replace the rear crank seal and pilot bearing.
The bolts aren't really an issue, neither will using loctite or FIPG.
Mr dude
Authorized Seller
Joined
Apr 10, 2007
Messages
17
Likes
Location
Rijssen
#6
Use loctite 545, I use it a lot at my work...
Loctite 545 Thread Sealant Hydraulic/Pneumatic Sealant, numbers 54505 and 54531. 545 is a liquid sealant for locking and sealing high pressure, fluid power systems with tapered fittings. Contains no fillers and will not foul valves or fluid filtering systems.
Mr dude
Authorized Seller
Joined
Apr 10, 2007
Messages
17
Likes
Location
Rijssen
#7
How would you seal the bolts then? If you don't use any kind of sealing, oil wil deff. leak into your bellhousing/clutch. Btw the original bolts have a tread sealing on them, if you buy them at an toyota dealer.
pimptrizkit
thread killer
Authorized Seller
Contributor
Joined
Dec 22, 2005
Messages
1,572
Likes
Location
vancouver Wa
#8
the green you see on the oem bolts is a form of loctight, not a sealer.
the holes are blind not open, meaning there is a bottom to them.
and unless some one really F-ed up durning machine work and drilled a hole were they didn;'t neeed one at all, just make sure the Rear-main is squar to the crank, "even". and that the oil pan is also sealed good.
also the rear oil gallery bolt may give you some issues if not tight enough of doesn't pipe thread tape on it.
i have re-used my flywheel bolts with no problem, so long as people fallow proper torque specs there is no issue, if you do not have faith in the last owner, purchase new one's.
improved
Running!
Authorized Seller
Joined
Apr 4, 2005
Messages
195
Likes
Location
California
#11
So final verdict? The holes on the flywheel are open.
I reviewed the MK4 TSRM and it didn't mention the use of FIPG or Loctite. Although I'd feel better if I used one or the other, but which.
Umm...
Thanks,
Matt-
tlo86
Authorized Seller
Contributor
Joined
Jul 24, 2005
Messages
3,914
Likes
Location
Colorado
#12
Umm...
Thanks,
Matt-
thats because they are TTY bolts and stretch. sealing it.
you cant reuse these bolts though.. you cant stretch a bolt twice. thats why some opt for the ARP... which in turn you'll need the loctite as ( i think ) is recommended by instructions.. you need some type of sealant though thats for sure.. i think ARP recommends loctite though... (since they do not stretch kind of thing..)
improved
Running!
Authorized Seller
Joined
Apr 4, 2005
Messages
195
Likes
Location
California
#13
I used Loctite Red. We'll find out if it leaks tomorrow, when I start the car for the first time in 1 year.
Matt-
CyFi6
Aliens.
Authorized Seller
Joined
Oct 11, 2007
Messages
2,972
Likes
Location
Phoenix
#15
It doesnt mark the flywheel bolts as a replacement part in the TSRM, only the flexplate bolts.
tlo86
Authorized Seller
Contributor
Joined
Jul 24, 2005
Messages
3,914
Likes
Location
Colorado
#17
when you say originals was it the 7m bolts? they should be different than the JZ and might be ok to reuse (im still iffy about it but i argue they are cheap enough to replace now and i didnt have a manual 7m or jz when i put my r154 on :))
Mr dude
Authorized Seller
Joined
Apr 10, 2007
Messages
17
Likes
Location
Rijssen
#19
For the 1jz you can use the ARP bolst from a 4AG engine. And to confirm again, use loctite because the holes are not blind.
