Figgie's build: Project Rodknox
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,630
Location
Shakopee, Minnesota
rapid prototyping,
Here is a 1/2 a template adapter for a transmission with more gears. This half is the transmission side.
Next is saying good bye to the R154 and ALL of the R154 mating components and work the engine side. Then put in a blender and mix them both to produce a working transmission adapter.
Then a flywheel, and input shaft adapter and off to the races in mating it all up.
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,630
Location
Shakopee, Minnesota
Back on the ibooster adapter.
So it fits, the length is off so going to have to make a bracket.
It is short by 23mm which sinks the brake pedal in to much.
The bolts you see sticking out of the red adapter are the adapter bolts. They are an interference fit so i did not want to press them in quite yet.
Now i have to make an adapter for the booster to pedal. The pin and width fit perfectly though.
Enraged
A HG job took HOW long??
Authorized Seller
Contributor
Joined
Messages
2,129
Location
Victoria, BC, Canada
Does it just have a threaded section you could swap with a longer one?
For the trans, are you trying to use stock parts (clutch, throw out bearing) with a modified/new flywheel? Or going everything new?
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,630
Location
Shakopee, Minnesota
Might as well answer forthright. :)
I am attempting to go DCT specifically the
Gs7d36BG from the 13-18 BMW M5.
I have the transmission already which is what i have been working on.
I got close but need to adjust the mounts as the 3d printed part is offset.
Enraged
Authorized Seller
Contributor
Joined
Messages
2,129
Location
DCT eh? Wow, that will be quite the change. It will definitely be a unique sounding MKIII shifting a DCT at full throttle.
I just looked up pricing on those, and wow they are cheap. Found a few for ~$1400, seems like it would be a great option versus a built a340 for someone with moderate power goals.
About your 3D printing, have you taken into account shrinkage? Just something to be aware of if you are printing large prototypes like that, you might get the print perfect and then discover a cut part isn't the same.
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,630
Location
Shakopee, Minnesota
Well technically it will throttle cut on the gear change but that can be programmed. These transmission are good for 700lbs-ft stock and with upgrades, good to 1100lbs-ft +.
On the 3d printed part, I use PETG to avoid shrinkage. So far, the measurements are off but not by shrinkage. I need to adjust the holes and the way the part lays so it has an inclusion for starter in the same location that the 7m is at. This initial design got me in the ball park. It is mostly to allow test fit before sending off to CNC.
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,630
Location
Shakopee, Minnesota
Another part!
This is just to test bolt fitting. Not sure on the direction yet.
Enraged
Authorized Seller
Contributor
Joined
Messages
2,129
Location
If you do billet covers, consider adding a provision for bolting down coils or a coil bracket (assuming non-stock coils). And maybe moving the vent ports to the very back of the cover.
Looks good though. 3D printers can definitely cause some snowballing on projects. Pretty soon you're going to be printing a prototype FFIM. Or one of those DIY header fit kits with the snap together tubing sections.... https://www.thingiverse.com/thing:1649639
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,630
Location
Shakopee, Minnesota
Lol...thankfully on the ffim, i am covered as i jumped on Sleeper Design's last group buy for 7M FFIM.
Though I just finished the CAD for the entire valve cover. Might adjust some things but not to shabby.
  • Like
Reactions: debrucer
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
2,454
Location
MKE, WI
Nice!
What's driving the need for new covers?
Integrating a cam sensor?
Re-plumbing the PCV?
Something else?
Enraged
Authorized Seller
Contributor
Joined
Messages
2,129
Location
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,630
Location
Shakopee, Minnesota
Nice!
Something else?
Honestly, I have been tossing around the dry sump idea and since I no longer have a power steering pump, that looks like a great place for one. :D
Toss in that I am running R35 ignition coils and now I have a need to make a center mount to actually mount them, then that gave me the ideal of valve covers with a middle portion to hide the coils. Think like the the jz does from factory just purely from aesthetics.
Are you using AutoCAD for 3D modeling? You should try Fusion 360, it's a great parametric modeling program, and you can get it for free as a startup or for personal use. I use it for small parts and personal business, and I use Catia, Rhino, and Autocad (2D) for my job.
For the writing, look at the Supra font that GrimJack made: http://www.supramania.com/forum/threads/for-everyone-who-wanted-the-mk3-supra-font.58091/
I use the Autocad 2020 student edition which watermarks the prints but since that is going to be sent to get milled. It still does the STL files that most CNC places need.
