Figgie's build: Project Rodknox
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,595
Location
Shakopee, Minnesota
Finally got the printer dialed in. This is almost like the 7M. Lol. The issue with the stair stepping was that the stepper motors did not have enough current going to them so they would miss a step. Had to adjust driver voltage upwards and that fixed the staggered layer issue.
Here is the finished product
Nice and true. Test fit time.
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
2,350
Location
MKE, WI
This is the adapter for the electric booster right.
Abe's 1987
Si vis pacem, para bellum
Authorized Seller
Joined
Sep 5, 2017
Messages
1,110
Location
Houston,TX
Those with the 3d printer should consider printing things such as little plastic pieces which break over time. I currently need the locking mechanism for ashtray in the center console next to the shifter. Do PM me if you guys can make me one or a few.
Abe's 1987
Authorized Seller
Joined
Sep 5, 2017
Messages
1,110
Location
Houston,TX
@Abe's 1987 's
It is not that straight forward. That little piece would need to be reversed engineer, put into a CAD software, printed, tested and then material finalized for large quantity production.
Isn't there any scanning system that can upload the design into the CAD program?
JustAnotherVictim
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
4,912
Location
Somewhere...
Some have laser systems for cmm but those are not cheap.
The place I used to work at had a metal 3d printer which I used to design and run parts on. It was very nice when I wanted to make myself something.
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,595
Location
Shakopee, Minnesota
Yeah, the 3d scanners that are are good cost a pretty penny.
3d printers that print metal are all laser based and then the 3d printed parts require heat treating afterwards.
Those printers start at 10k for tiny volumes. Add furnaces etc and business needs to have 20k in capital and the electrical power requirements are not home friendly.
JustAnotherVictim
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
4,912
Location
Somewhere...
I think the machine itself was about 150k not counting installation.
Forgot to mention it would only make parts that could fit on a 4" disc build platform haha.
  • Like
Reactions: figgie
Enraged
A HG job took HOW long??
Authorized Seller
Contributor
Joined
Messages
2,114
Location
Victoria, BC, Canada
  • Like
Reactions: figgie
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,595
Location
Shakopee, Minnesota
ok, this is so intresting. So the tesla studs are an exact pitch thread match.
The pin that is used to connect the MKIII Supra Master brake cylinder to brake pedal fits loosely on the pedal. I can see that being sloppy on the pedal.
With that said, it fits the same exact way in the tesla iBooster rod sleeve. :eek:
  • Like
Reactions: Piratetip
