Figgie's build: Project Rodknox
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
Ok, took some time to do some polishing.
Here we have an ATI Clear cover, not sure what was drug across the face but it was definitely abrasive
As you can see, the top part is clear, not the lower part.
This is after 1st pass on 500 grit
2nd pass at 800 grit
3rd pass at 3000 grit wet sanding
Final pass with rubbing compound
I think this would have benefited from a 5000, 8000 and 12000 pass before that but looks heaps better
Now to seal it and that is done.
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
My OCD could not leave well enough alone...
I went to 12000 and used wolfgang uber all in one to cut, polish and seal.
  • Like
Reactions: suprarx7nut
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
This is the next project for the supra I am working on. Yes I designed them myself :)
It is just a rough idea for the dash.
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
It would be super cool if someone could make an LCD or led screen that could take up the whole stock gauge cluster and digitize it all, but I know the stock shape would make it difficult.
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
That would be damn sweet.
The bad part is size needed which means price.
You are talking what Mercedez Benz uses on their current model line up which is big and then you need a way to program it (now you need programming, uix design etc).
Would be cool regardless but the Lexus UIX design is compact and works really well.
For my car, this will be the only thing for didplay. There will not be additional gauges of any sort.
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
2,410
Location
MKE, WI
Sounds like a good plan.
I tend to only really use gauges when there is an issue I am trying to diagnose or keep an eye on something I know might be failing.
Otherwise once the car is dialed in I use pretty much nothing but vehicle speed.
I like to turn off the radio, crack the windows and just hear the RPM, and engine overall.
Similar sidenote:
I wish the Tesla had a way to hide the gigantic distracting screen.
The driving experience would be that much better to just be able to drive and enjoy, minimalism.
I feel like Tesla is really missing the point on this.
The only closest way I found was to put the screen into cleaning mode, but that's not ideal.
I don't get the need for all the screens these days.
Incredibly distracting.
A-to-the-J
Panda™ and Pre-89 Gracer™
Authorized Seller
Contributor
Joined
Feb 19, 2006
Messages
1,096
Location
Irvine, CA
Guess I’ll stop lurking. LoL. Awesome build figgie. I think I would definitely take my time if/when I pick up another A70. Probably make it a project for me and my daughter.
Have you seen the Defi Super Sports Cluster?Its pretty minimal and might be up your alley, possibly cheaper than a custom screen. It just has boost and a tach with a pretty damn customizable screen.
3p141592654
90T
Authorized Seller
Contributor
Joined
Oct 11, 2005
Messages
4,244
Location
Thousand Oaks, CA
If anything screens are getting bigger. Like this new interior from VW.
Back in 2005 I wanted to patent a configurable dashboard screen because I could see it was definitely the future. Unfortunately I found out Delphi had already patented it a few years earlier.
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
Thanks for that.
I actually put the order in for the dash already. :)
I do appreciate the input though!
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
Yeah, MB started the big screen thing with the s500 and now it is just going in all the cars.
Intresting that vw did it but Audi is still dragging feet.
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
direction getting clearer as I progress on the dash design
this is pretty involved. Left to add
Oil Pressure and Temp
Coolant Temp (with homage to the MKIII for the Bird cage)
Fuel Pressure and Fuel Temp
E85 %
Throttle Position
optional that I am debating in putting in.
Brake Pressure
G Meter
Outside Temp
Turbo Speed
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,410
Location
MKE, WI
Gotcha.
So that sensor outputs digital square wave, nice.
  • Like
Reactions: figgie
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
My guess is maybe.
I have not tested the sensors. I can see hall effect having issues with trying to keep up at 100k RPM though on a VR based, i would have concerns on the voltage output at 100K Rpm. lol
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,410
Location
MKE, WI
I was just reading the Garrett documentation on the sensor itself for the GT series.
Says output signal just for the sensor is already conditioned. Outputs square wave at 1/8th the input speed.
So just a simple formula to adapt it to standalone or for different than 8 blade compressor wheels.
Looks simple.
  • Like
Reactions: figgie
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
Looks simple.
Well i am eyeing a Garrett Turbo as part of the refresh of this car so it should be a drop in ordeal.
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
I can blow so much time with display layout. I have been using Adobe UI for the big image designs..
I got one alarm setup tied to the engine coolant. It actually turns on at 210F but I pegged it for testing to make sure the logic works.
I am looking for a sharp bird cage image to display. with the alarm.. but you get the point.
  • Like
Reactions: 3p141592654
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,410
Location
MKE, WI
Oh no, you are carrying over the birdcage light!?
LOL, j/k
Way way back my friends riding with me would say. " Your birds got out of the cage"
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
LOL, j/k
I AM. That bird cage is the 7m staple... birdie is out of its cage!!!
But the bird cage is not tied to temp and instead just the sensor in the overflow bottle.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,410
Location
MKE, WI
It is iconic. Probably should keep it.
Yeah I know it's just the overflow.
  • Like
Reactions: figgie
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
Almost there!
Undecided if to show GPS or compass on upper right hand side.
and drawing a blank on what to put on lower right hand quadrant.
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
223
Location
Lexington, Ky
Is there anyway you could program in the outline of an a70 for the bottom right corner? That would be pretty neat.
Enraged
A HG job took HOW long??
Authorized Seller
Contributor
Joined
Messages
2,116
Location
Victoria, BC, Canada
Looks good, I second the compass on bottom right, it would match nicely with the g-meter.
Have you considered using the Supra font?
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
it crossed my mind, the bad part is that Supra font is a Toyota IP. If i was doing this just to mess around i would make those fonts but the company i am doing this for is a a full fledged MoTeC dealer and that is getting into murky waters.
Enraged
Authorized Seller
Contributor
Joined
Messages
2,116
Location
The Supra font I have was created by Grimjack years ago. "Inspired" by Toyota I'd imagine, but not their IP. I'm not sure if he posted a use license or not.
Authorized Seller
Contributor
Joined
Messages
8,813
Location
Well, I am using this as a place holder for pictures and information.
lets start with the basics.
MFG: Toyota
model: Supra
Body style: 2 door TARGA
YEAR: 1989
Patient Condition: the car is in ok shape. The car made 550 rwhp on E85 so the motor was in good form. No rust (amazing for a Minnesota car). The bad news is that the previous owner thinks it blew an HG. After hearing what happened and when it happened, I am thinking it might be something less ominous than the typical BHG (it has a MHG and ARP studs along with a built bottom end). It is on an AEM but unsure of version but of course I need the patient under the knife to really tell. The car is currently not running and it also suffers from vampiric battery drain (most likely culprit will be the stereo system).
Good to see you around. I sold my most recent in 2018. I doubt I will try again.
  • Like
Reactions: figgie
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
Yeah,
this time just taking my time. amazing what some perspective in ones life does for some of the hobbies :D
BTW, I get it! it is overwhelming if scope creep rears it's ugly head. :(
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
So many moving parts!
Here is everything this supra is getting
Not seen is a ltc-ntk for wideband and a dual half bridge for control of the active differential.
Before all this, i got the last two wire rolls finally which 1 was critical as it is for can communications.
The FFIM is a sleeper design machined work of art. Throttle body is from the supercharged LT4 engine.
  • Like
Reactions: Piratetip
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,410
Location
MKE, WI
Oh that's pretty.
Some high dollar stuff right there. :D
Whats the response time on the NTK?
Or the better question would be the response time on the controller.
I have been trying to decide on a good wideband, haven't made the choice yet.
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,615
Location
Shakopee, Minnesota
Oh that's pretty.
I went with the NTK as they tend to be a bit more robust than the 4.9 and handle the richer Lambdas better. This was according to a couple of guys I talked to that race X275 professionally and they all run NTK on Methanol cars (along with EGT). They all mentioned the same thing, be careful of how you mount them and specifically the 4.9 as it does not take thermal shock well at all.
I would have loved to try out the LSU ADV but not many controllers as of yet and there is no longevity data for the LSU ADV either. :(
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,410
Location
MKE, WI
Yeah there is a big mess of widebands out there, with not a lot of good data.
Or rather side by side comparisons showing real data.
So its a 4.2 sensor?
