Engine dies after half second start up E MANAGE ULTIMATE
Renierwellens
Authorized Seller
Joined
Oct 29, 2018
Messages
Hi all,
I am trying to get my car started with the E Manage Ultimate. It starts for half a second and dies afterwards. Sometimes my jumper settings should be open, in the manual it says sometimes otherwise than on my board (other way around).. A lot of confusion here! Also the 7mgte is a karman vortex Airflow type but there stands nothing for Toyota so I have chosen Flap type 2 on a recommendation of someone.
I have tried a lot of things like the 5v / 12v ignition output switch etc but no luck.
Anything that I can try? I have provided photos.
This build is getting really frustrating.. Thanks in advance!
If I can provide any other info that you would need. I have tried contacting Trust/GReddy but they give me no answers.
PS: Car worked perfectly before adding the EMU.
Kind regards,
Wellens Renier
Renierwellens
Authorized Seller
Joined
Oct 29, 2018
Messages
Can you upload the file for the tune?
Sure, here is the link: https://ufile.io/g7k0y
Please don't mind a few settings, I am trying some few things.. Hopefully you can see what the problem is. Also I have changed the igniton output (at the jumper settings) to 12v since the igniter and coil pack requires 12v.
I have used the data log feature, I get Airflow (input + output), injection, ...
JDMMA70
Well-Known Member
Authorized Seller
Joined
Dec 4, 2006
Messages
2,675
Location
Houston
Ok let me make a few more changes, sorry for the delay, Ive been busy with finals.
Renierwellens
Authorized Seller
Joined
Oct 29, 2018
Messages
Still no luck, thanks for all the help. I will get it a professional tuner, I am really getting sick of it.
I'm not getting enough fuel but I can't understand why. I get 19/1 A/F and the EMU thinks it is getting 130 celcius intake temp.
Renierwellens
Authorized Seller
Joined
Oct 29, 2018
Messages
I've changed that now, it was closer to the real temperature. But for the intake it is all around 130 degrees celcius so I have put that setting off.. Might need to check the wiring again. Thanks for the input. I'm still not giving up :p
Edit: I am currently checking my wiring harness. Connector C pin 8 Knock Signal/IAT (from the E manage) is connected to the knock signal (from my ECU). Shouldn't I connect it to the THA (IAT) from my ECU ? I know in a stock ecu when IAT sensor is bad a car can stall but when the E manage has no readings it reads stock ecu signals or does it think it has a bad sensor/no sensor so that is causing my stalling? Thanks in advance
