ECUMASTER DET3 QUESTION
Z06gette
Authorized Seller
Joined
Apr 29, 2018
Messages
112
Likes
5
Location
Yorkville, IL
#1
I will be using the ecumaster DET3 to tune my 7mgte HX35 setup. I've downloaded the manual and read through the DET3 thread that is on here several times. My question is, I see ecu masters have a “base map” specifically for the 7mgte on their website under downloads. Is this something I should download?
Z06gette
Authorized Seller
Joined
Apr 29, 2018
Messages
112
Likes
5
Location
Yorkville, IL
#2
I plan to install it tomorrow so if there are any DET3 users, current or former out there that can shed some light I would appreciate it!
Authorized Seller
Joined
Apr 17, 2007
Messages
12,742
Likes
25
Location
Orange, CA
#3
Yes. You should start with the base maps.
It’s should not be used for anything other than limp mode basically. Still needs full tune.
Authorized Seller
Joined
Apr 17, 2007
Messages
12,742
Likes
25
Location
Orange, CA
#5
Not totally as setups are not always the same. But it’s something to start.
Starting with nothing is not something you want to do.
Z06gette
Authorized Seller
Joined
Apr 29, 2018
Messages
112
Likes
5
Location
Yorkville, IL
#6
Definitely. Weather was garbage Sunday so I’ll be installing it sometime this week. I’ve been using efi systems wide band which doesn’t allow data logging so I got an AEM wideband yesterday. I need to log some with the stock afm and o2 before replacing it with the speed density setup and reference on the tune instead of the stock o2?
Authorized Seller
Joined
Apr 17, 2007
Messages
12,742
Likes
25
Location
Orange, CA
#7
The ecu master should have built in datalogging. Don’t need datalogging on the wideband.
Once it started then you need to change the fuel map to get it correct.
Of course all the other settings need to be checked as well and all sensors need to be calibrated.
Z06gette
Authorized Seller
Joined
Apr 29, 2018
Messages
112
Likes
5
Location
Yorkville, IL
#8
Oh okay, I was under the impression you had to add the wideband as an output to replace the stock o2. Then do logs with the unit to fill in the blanks. Thanks for the info!
Authorized Seller
Joined
Apr 17, 2007
Messages
12,742
Likes
25
Location
Orange, CA
#9
No. You use the output from the wideband and connect it to the stand alone. There should be a dedicated pin usage for it. Or at least a standard one.
You want the standalone to have all the real time info from the sensors.
