Dual Projectors
Backlash2032
Authorized Seller
Joined
Sep 20, 2010
Messages
1,823
Likes
Location
Nebraska
#1
I saw these on (i believe) Rodels Supra, and wanted them on mine. I was wondering if there was a way to have dual projectors on each side, with HIDs?
If thats not possible, how hard would it be to put dual halogen projectors in each headlight bucket?
I just love the look of it. haha
Authorized Seller
Contributor
Joined
Messages
Likes
Location
#2
One is a projector, the other is a reflector high beam. They're hella 90mm units.
Not cheap and quite difficult to install and get everything right (trust me, I've been working on a semi-bolt in kit for a while now)
Backlash2032
Authorized Seller
Joined
Sep 20, 2010
Messages
1,823
Likes
Location
Nebraska
#5
What projectors did you use?
And how did you modify the wiring/headlight switch so it knows to switch bulbs when switching from low --> high beams?
rodama5anthony
Authorized Seller
Joined
Sep 24, 2010
Messages
430
Likes
Location
Bay Area, CA
#8
bi xenon hi/low hid projector and a random fog light projector
the headlight wiring was easy cus you dont have to do anything except plug in the h4 to the hid but the fog lights were much more difficult
---------- Post added at 10:39 AM ---------- Previous post was at 10:38 AM ----------
I guess i dont understand how they work with the single bulb..
in the bi xenon there is a reflector inside that moves wen you activate the highbeam
Backlash2032
Authorized Seller
Joined
Sep 20, 2010
Messages
1,823
Likes
Location
Nebraska
#9
So you wired the fog lights to the outer projectors and then had high and low on the inner?
I was thinking high low in two different projectors. If i understand correctly, theres three wires on the headlight bulb, (I think.. hahaha) and one of them is for lows, and one is for high beams, and then a common ground? In stock form of course. Is that correct?
Joined
Aug 12, 2010
Messages
347
Likes
Location
P.G. County, Maryland
#12
There is one Posi and two earth wires. I was just talking about doing this in another thread lol. As Poodles has already said, it is by no means a bolt on procedure. Some people do HID's and a reflector, but i wanted to do two matching sets of bi-xenon projectors with two matching sets of HID capsules. The cost for this setup (If done properly) is ridiculous, and that is one of the reasons there are no bolt-on kits available. They would easily cost 2k+. I don't like the bug-eyed look of using one larger projector in a square housing as some others have done, so i chose to keep my square reflectors as low/high beams, and instead swap out my fogs for large diameter projectors with HID's in them. Some people have voiced concern in regards to my decision, but i believe that with the proper modifications it will work for what i need. Just letting you know that there are alternatives to the norm, but do what suits your needs and driving style. theretrofitsource.com has alot of useful information and parts if you need them, and hidplanet.com is an automotive lighting forum you may want to look at, it will also be very helpful.
Speaking of TAKING FOREVER, when are those lights of yours gonna be ready Poodles?:icon_bigg
Authorized Seller
Contributor
Joined
Messages
Likes
Location
#13
Supplier is taking forever, parts are on backorder and they THOUGHT they'd ship friday...but didn't.
Backlash2032
Authorized Seller
Joined
Sep 20, 2010
Messages
1,823
Likes
Location
Nebraska
#14
Okay, deff. not getting 4 sets of HIDs. Wayy to much money. Ill just get 4 halogen projectors. That sounds like it would be enough light anyway.
And rodama5anthony, you need to do that write up. My main concern is mounting the projectors and getting the headlight to only come up so far. In my head, it seems like if you shorten the arm that attaches to the headlight, or the arm that comes off of the motor, the headlight will go lower than it should when you lower it, then you have to compensate for that, so the headlight will just go up to the same height as stock.. Maybe im just overthinking this.. haha
Authorized Seller
Contributor
Joined
Messages
Likes
Location
#15
Of note, rodam's setup isn't legal (low beam has to be on outside), but most places won't look that hard. If my other setups sell well I plan on getting the other setup made. Right now I could make it but it would be lacking a shroud and I just don't think it's up to my standards.
Also of note, the 90mm hella modules are sub-par for projectors. They are still HUGE upgrades over a stock sealed beam though, and the H9 bulbs are extremely bright. There are far better projectors out there, the issue is that they're not sealed so they have to be installed into some kind of housing.
If money was no object this would all be done by now :rofl:
Joined
Aug 12, 2010
Messages
347
Likes
Location
#17
The Mk3's headlihts aren't like the 240's. The headlight motor makes one full revolution every time it is switched on, so simply cutting the rod won't work. The cheapest and easiest way to get sleepies would be to use the adjustment knobs next to each headlight to get them where you want them, then unplugging the plug to the bottom of the motor. The headlights will still turn on and off as normal, but your motors will not move. The downside to this would be that you are stuck in sleepy mode, and can't put your light up or down. All you would need to do reverse it is plug the motor back in. I wouldn't suggest this mod unless you have HID's or a retrofit, because you will only have light from the top edge of your sealed beam light, and it's like your headlights aren't even on if you do it with the stock lights.
Backlash2032
Authorized Seller
Joined
Sep 20, 2010
Messages
1,823
Likes
Location
Nebraska
#18
I know ive seen people where they mod the headlight to move up and down like 2 inches.. I think you have to mod the arm that comes off the motor, but that still doesnt make sense to me..
rodel
SoCal
Authorized Seller
Joined
May 19, 2005
Messages
2,296
Likes
Location
SoCal
#20
2 hella 90mm projectors won't fit on the same side. I tried.
My lights r wired like how u describe. The projector is low beam (hid), the high beam unit (halogen) turns on with the high beam light switch. Sorry, but I wouldn't be able to explain how to do it, I had someone else do the wiring.
I'm gonna change my setup by putting lexus ls430 projectors (the best of projectors) into h4 housings.
rodel
SoCal
Authorized Seller
Joined
May 19, 2005
Messages
2,296
Likes
Location
SoCal
#22
Yeah i think im just going to use two halogen projectors.. I dont feel like messing around with HIDs. haha
Fyi....they would be wired the same way.
Authorized Seller
Contributor
Joined
Messages
Likes
Location
#23
I'd argue the LS460 is the best projector (as they're bi-xenon and the LS430 is only low beam), but they're a bit large...
Backlash2032
Authorized Seller
Joined
Sep 20, 2010
Messages
1,823
Likes
Location
Nebraska
#24
I wouldnt have them wired the same way as you, as I would be switching between bulbs for high and low. You have it set up so when high beams are on the HID switches to high beam and then the second halogen projector turns on, correct?
rodel
SoCal
Authorized Seller
Joined
May 19, 2005
Messages
2,296
Likes
Location
SoCal
#25
My Hella 90mm projector modules are not bi-xenon (low beam only). Additionally, I have Hella 90mm high beam modules (non-projector).
My headlights turn on in the following ways:
low beam HID "ON"
OR
low beam HID "ON" and high beam "ON"
Why would you need the low beam HID to turn "OFF" when the high beam is turned "ON"....since the high beam would overpower the low beam? Also, because of the brightness of HID lighting inside a projector, hardly is there a reason to turn "ON" high beam; hence, the reason that I have a halogen bulb in my high beam modules (no need to spend on HID).
Poodles: You've been talking about creating a light setup for a looooooooooooooooooooooooooooooong time. :cry:Let's see results, at least progress. :thumbup:
Authorized Seller
Contributor
Joined
Messages
Likes
Location
#26
A semi bolt-in setup like yours is just to expensive for me to make at this time :cry:
Sure, I could slap something together, but I have high standards and don't like cutting corners, especially if I'm going to sell them.
Backlash2032
Authorized Seller
Joined
Sep 20, 2010
Messages
1,823
Likes
Location
Nebraska
#27
low beam HID "ON"
OR
Oh, I was under the assumption of you had bi-xenons. Sorry.
And honestly, I just dont have the cash flow to dump extra on a set of HIDs, plus i would have no idea how to wire it. Switching bulbs would be much easier to wire in
rodel
SoCal
Authorized Seller
Joined
May 19, 2005
Messages
2,296
Likes
Location
SoCal
#28
I'm sure there are electrical gurus here that could help you.
rodel
SoCal
Authorized Seller
Joined
May 19, 2005
Messages
2,296
Likes
Location
SoCal
#29
If you have welding skills, this is an good setup that could be easily made:
Authorized Seller
Joined
Apr 17, 2007
Messages
12,742
Likes
25
Location
Orange, CA
#30
Low beam hids have 2 wires. power and ground. You will need balasts , bulbs and projectors tho.
From a hyundai genesis
rodama5anthony
Authorized Seller
Joined
Sep 24, 2010
Messages
430
Likes
Location
Bay Area, CA
#31
I live in CA so my set up is probably illegal but i never use the high beams.
i believe the head light does a half revolution not a full revolution when turned one other wise it would just end up closed again. and you have to cut both arms to get working sleepeyes and reweld the ball joint onto the arm that is directly connected to the motor. and yes at first i did have problem with the angle of the light at first but it was as simple as buying a longer bolt for the up and down adjustment on the headlight housing.
Backlash2032
Authorized Seller
Joined
Sep 20, 2010
Messages
1,823
Likes
Location
Nebraska
#35
Correct, completely different. The hardest part of that entire assembly is the bezel around the lights...
Any chance that that assembly would bolt into the supras housing, since the mr2 and the supra share the same size headlight? Then make a custom shroud?
rodel
SoCal
Authorized Seller
Joined
May 19, 2005
Messages
2,296
Likes
Location
SoCal
#36
Nsx conversion is cool...but still halogen.
---------- Post added at 10:22 PM ---------- Previous post was at 10:18 PM ----------
The only way to find out is to buy the mr2 setup. Do it!
Backlash2032
Authorized Seller
Joined
Sep 20, 2010
Messages
1,823
Likes
Location
Nebraska
#38
I might.. I have to compare the cost of buying projectors and doing the work myself vs. the mr2 kit..
Just saw poodles post.. maybe not.. hahaha
rodel
SoCal
Authorized Seller
Joined
May 19, 2005
Messages
2,296
Likes
Location
SoCal
#40
You're better of having a set fabricated for your car that is sure to fit.
---------- Post added at 01:00 AM ---------- Previous post was at 12:59 AM ----------
It'll be done when i have enough suspension work done to chase down an NSX in the swervies, and enough power to reliably eat corvettes and shit mustangs.
At the least, I assume that you're referring to an NSX with a legit driver, a Z06, and GT500.
When you've chased down, the NSX, eaten a Z06, and have had a GT500 exit out your rear end, you either have built one of the best handling 200MPH+ MK3 ever (and you are a legit driver) or decided to stop toying around with an MK3 and got down to business by purchasing another car like a 997 GT3 RS and you are a legit driver). :naughty:
