cutting out and backfiring at 2200rpm
GreenChevelleSS
Danny
Authorized Seller
Joined
Dec 17, 2005
Messages
523
Likes
Location
Tulsa, okiehoma
#1
Started having an issue where the car will cut out and back fire between 2000-2500 rpm. it happens in every gear no matter the throttle position.
need advice on what to start trouble shooting.
Ive checked codes and only have code 34 and know thats no the cause of this. Im pretty sure its something with the ignition.
7mgte, CPS is about a year old and about 500 miles on it.
BWs362. DET3, 560cc injectors, afpr
https://www.facebook.com/daniel.gillean.7/videos/10154048212819669/
This is a video I took of it on the highway in 5th gear. at one point i WOT it and nothing changes
GreenChevelleSS
Danny
Authorized Seller
Joined
Dec 17, 2005
Messages
523
Likes
Location
Tulsa, okiehoma
#2
SO today I replaced the CPS, Ignitor, Coil pack, Coil pack ground wire and ran to the battery and its still the same. Ive gone over the wiring and all my piggyback wiring and Ive had no luck. Ive got another ECU to try and im gonna order a new TPS. I just dont know what to do.
GreenChevelleSS
Danny
Authorized Seller
Joined
Dec 17, 2005
Messages
523
Likes
Location
Tulsa, okiehoma
#7
So I've retimed it and installed a new TPS and adjusted it correctly. Still the same. missing at 2000-2500 rpm.
Also cut off all the injector connectors and resoldered all new ones on.
GreenChevelleSS
Danny
Authorized Seller
Joined
Dec 17, 2005
Messages
523
Likes
Location
Tulsa, okiehoma
#9
So I just did the 2jzge swap, used the 7m harness and ecu. Its still happening. I havent done any diag on it yet but I changed to vvti ge coils and removed the 7m coil pack connector and Denso 4 wire o2 sensor. and its still there. When I get the car back from exhaust shop will dig into it more. wondering if its in the tune or injectors.
plaaya69
87T Supra
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,366
Likes
77
Location
Lake County, IL
#10
Are you still using the 7m CPS sensor? How are the grounds on the cylinder block and cylinder head?
GreenChevelleSS
Danny
Authorized Seller
Joined
Dec 17, 2005
Messages
523
Likes
Location
Tulsa, okiehoma
#11
Yes still running 7m cps, I have 2 and it did the same with both. Grounds are good I made sure of that when putting it in. Im probably gonna add another block to body ground but I have the original one by the exhaust that goes to the head.
GreenChevelleSS
Danny
Authorized Seller
Joined
Dec 17, 2005
Messages
523
Likes
Location
Tulsa, okiehoma
#13
Im running an AFPR and it does it at all loads. The fuel pump resistor has been bypassed for diag reasons also pertaining to this problem. The fuel pressure seems to be alright at idle and free revving but i dont have a gauge inside to monitor it while driving. I plan to upgrade the pump soon to a aeromotive 340 or the mkiv TT pump.
