Cranks but no start after head gasket replacement
suprasick
Hey look...a Supra!
Authorized Seller
Contributor
Joined
Mar 17, 2006
Messages
309
Location
Milton, Washington
So the car runs if you add a fuel source like ether or carb cleaner?
Yes. If I disconnect the fuel pump. Badly of course but it runs.
Without ether, when I pull the plugs they are drenched in fuel. I used a potentiometer connected to the water temp circuit and got the injector pulse down to 8ms. And the plugs are still covered in fuel. I then turned the fuel pressure down as far as it can go to 20psi and still the same problem.
Each time I try something new I have to remove all the plugs to clean and dry them off.
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,367
Location
Shakopee, Minnesota
thought I circle around back on this.
if your fuel injectors are drenched, and the injectors seem to be injecting correctly via the o-scope reading.
That leaves;
the cold start injector staying open all the time.
Injectors are stuck open across the board
the wiring to the fuel injectors is hitting a ground point somewhere
Since you swapped out TCCS for the EMS and still the same problem, it starts to sound like fuel injector wiring hitting ground.
