Crank trigger mod
shadowman1977
Authorized Seller
Joined
Jun 4, 2015
Messages
170
Location
Kingston N.Y. 12401
Hello all. Has anyone tried to install a crank trigger wheel and timing gear off of a 1J or 2J onto a 7M? I need some form of crank trigger for the new ECM. I found pics and part numbers. 478BD09E-1E17-4FB5-AF62-494B65C2C006.png 405CF9F4-B4A9-44FD-87FB-5254FCFEE9B5.png 478BD09E-1E17-4FB5-AF62-494B65C2C006.png
Authorized Seller
Joined
Apr 17, 2007
Messages
12,762
Location
Tokyo,jp
You can use the cam sensor. It has 12 tooth for crank and a single for cam.
Also I think dm sells a new type of sensor
  • Like
Reactions: shadowman1977
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,389
Location
Shakopee, Minnesota
60-2 would be great on the crank.
More teeth means more accurate timing reading (less drift).
I have seen 120-4 and of course the optical system from Ford and Nissan are at 360 degrees.
  • Like
