With the CPS, I've experienced a problem where the CPS itself worked, but the original CPS wiring harness was old and brittle and the CPU wasn't receiving the signals; I would check to make sure that is ok. You can buy a new CPS harness from Driftmotion for petty cheap. Not saying that's the issue, but you may want to check that the signal is making it to the ECU.I could really use some advice on where to look. I have a 1987 Toyota supra and it cranks but doesnt start. I checked my CPS and it checked out good resistance wise.
