Code 12, Cam Position Sensor failure
traingeek2000
Authorized Seller
Joined
Aug 8, 2018
Messages
12
Likes
I've been having starting issues on my '91 turbo since I got it. After a couple of fix attempts, including a new battery and starter (pita), I finally reached a crank/no start situation. I'm throwing a code 12 for no cam position signal.
At the same time as this problem developing, I also had all six injectors spraying into the cylinders, flooding the engine. Is this related to CPS failure?
Before I start a search for a new sensor, are there any techniques for diagnosing the sensor and its associated wiring? I haven't found any diagrams for the plugs and where they go, so I wouldn't want to replace the sensor only for it to be a wiring problem.
traingeek2000
Authorized Seller
Joined
Aug 8, 2018
Messages
12
Likes
Turns out my timing belt failed. Took the cam cover off, cranking the car doesn't turn the timing belt. Oof.
suprajim54
Authorized Seller
Joined
Sep 2, 2009
Messages
134
Likes
Location
Dallas, Texas
#4
The belt is broken or just doesn't turn when cranking? It's a non-interference engine so no worries about damage to valves/pistons. If the belt isn't broken then you probably either broke the spring on the tensioner or the cogged pulley on the crankshaft is broken.
traingeek2000
Authorized Seller
Joined
Aug 8, 2018
Messages
12
Likes
Actually, it's much worse. Taking a 3-foot breaker bar to the camshafts doesn't turn them. My camshafts seized up.
I don't know what I'm gonna do. I'm going back to college in a few days, so there's nothing I can do about it for a good long while. Time to think, however.
suprajim54
Authorized Seller
Joined
Sep 2, 2009
Messages
134
Likes
Location
Dallas, Texas
#7
You can't move either one of the camshafts? If just the exhaust side is stuck, maybe the gear teeth on the CPS and the camshaft aren't lined up preventing you from turning them? Just spitballing here
cinderMK3
I want all the HAm
Authorized Seller
Joined
Apr 13, 2015
Messages
164
Likes
4
Location
Akron Iowa
#9
How destroyed is that belt? the cams not turning while that thing cranking on must of shredded that thing..
