Clutch Issue Need Help
oldmansupra
Authorized Seller
Joined
May 2, 2010
Messages
152
Location
Canada
I swapped a 2jz-gte vvti from an aristo into a mk3 supra. The engine runs great but when I push the clutch down it makes a grinding scrapping noise at 80% clutch pressure and the engine stalls out if I press it to the floor. See the YouTube video here, I’m going to removing the transmission and see how the clutch is installed, any ideas?
oldmansupra
Authorized Seller
Joined
May 2, 2010
Messages
152
Location
Canada
After a closer inspection tonight the fork is clearly hitting the clutch as you can see the red paint is chipping which would be the grinding noise. Something must be installed incorrectly but I’m still unsure of what. There shouldn’t be that much play in the clutch fork.
plaaya69
86.5 Turbo Converted Supra
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,485
Location
Lake County, IL
I know when I installed my ClutchMasters FX400 clutch it had a sticker with a "flywheel side" on the disc, did your disc have that or any type of facing direction on it?
oldmansupra
Authorized Seller
Joined
May 2, 2010
Messages
152
Location
Canada
Took the transmission off this weekend and the disc is on correctly. However, there was a 5mm spacer between the flywheel and the engine which I think was for the automatic transmission.
Authorized Seller
Joined
Apr 17, 2007
Messages
12,760
Location
Tokyo,jp
Ya the spacer is for a auto flexplate. Not needed for manual trans.
