Changes, but make sure!
Steven Hohmann
Joined
Jun 7, 2019
Messages
My 1987 supra base sport roof,ha,had an automatic trans.It went bad.I purchased a R-154,had it rebuilt.
Will it fit???
Thank You
Steven H.
plaaya69
86.5 Turbo Converted Supra
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,498
Location
Lake County, IL
Of course it will fit. I did the same swap to my 87 but you also need a r154 driveshaft and need to modify the shift boot plate with 4 10mm bolts that mounts to the body as 2 of the rear bolt holes will be slightly different on that metal plate. You also need to bypass the automatic neutral safety switch and hook up the reverse lights if you want it wired in right from the automatic engine harness.
