Cam Shaft Positional Sensor
JGD
Authorized Seller
Joined
Jan 12, 2019
Messages
9
Hi Everyone. Has anybody had issue where the car stall at stop sign or idling? It doesn't do it all the time. I have check the wring and change the wiring harness but still is doing it sometimes? Can anyone help?
Black95
Authorized Seller
Joined
Sep 19, 2010
Messages
68
Location
Calgary
I had a problem with a different car where it would stall intermittently and not start for a while. Then it would start and run fine, until the next time it stalled. Warm, cold, didn't seem to matter.
It turned out the timing belt was off by a tooth.
(Not a supra and not a Toyota.)
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
2,308
Location
MKE, WI
I've had this issue with an old worn out CPS.
Old brittle wiring + corrosion + old coils = very weak signal.
Especially once everything gets hot.
I've made a thread here going through the CPS signal quality and how to fix it.
  • Like
Reactions: JGD and plaaya69
