Block heater?
Clip
The Magnificent Seven
Authorized Seller
Joined
Oct 16, 2005
Messages
2,739
Likes
Location
North Carolina
#1
hey all,
went to start the power wagon this morning and it was pretty picky. after spraying some starter fluid down the intake it would fire up, but didn't wanna fire by itself. i have no problem from around 38 degrees upward, so I was wondering if anyone sold a generic block heater that i could plug in at nights.
is it possible to safely make one if i can't find one at any store?
RHDMK3
that's it!
Authorized Seller
Joined
Sep 30, 2006
Messages
447
Likes
Location
Salem, Oregon
#4
Well I've never had to use one either, but my guess is one of those should be fine, unless you are living in Alaska or somewhere like that.
jimi87-t
Authorized Seller
Joined
Oct 12, 2005
Messages
1,122
Likes
Location
Colorado Springs
#5
My bimmer was hard to start in the cold last year, so this year before the winter hit I installed an oil pan mounted warmer. Similar to a heating pad that sticks to the oil pan, from testing this with my temp probe the oil temp would go from 35*F to 110+*F in about 2 hours, this will all depend on things like wind ect.. (drastically cutting down cold start wear).
Pre-warming the oil is the best for your motor IMO. But your coolant will not be as warm as with a block heater, so you won't have full heat in the cabin when you go out to start the car (but personally I'm more worried about cold start engine wear than having the heater right away, plus I have remote start on the bmw). This year I have had no issues starting up in the cold. Plus I have the peace of mind knowing the oil is warm and flowing, were as before when starting in the cold my sphincter would be clinched knowing how cold and thick the oil was on start up.
I have this plugged into a timer to come on 2 hours before I start my car in the morning. You can leave it plugged in over night, but I have not done any testing for more than 2 hours. I got mine from a company called Proheat, I found out about this product from over the road Simi-truck drivers that swear by these heaters. IF YOU ORDER FROM THIS COMPANY, call them! as their online order form IS NOT SECURE. I found out the hard way, but this was not the Proheat company that ripped me off.
A couple of down falls of block heaters are, they impede coolant flow when the motor is running as the heating element is in the passage way, and the oil is still cold when you start up.
I've heard (take it for just that, hear-say) that they can create hotspots that can cause warping. :dunno:
Clip
Authorized Seller
Joined
Oct 16, 2005
Messages
2,739
Likes
Location
North Carolina
#6
im talking about a magnetic heater. i'd be able to stick it most places on the block itself, or the oil pan, correct? would heating just the block make a difference in cold starts?
i'm really only looking to make the engine easier to start in cold weather, would i worry about the oil or the coolant more (i dont mind if cold oil or coolant is hard on the engine, just need the thing to start up and keep running).
jimi87-t
Authorized Seller
Joined
Oct 12, 2005
Messages
1,122
Likes
Location
Colorado Springs
#7
I would think you could put it anywhere that it would grab, just use commonsense and keep it away from fuel lines, or anything that could be damaged from too much heat.
I think if it is a sensor problem (sensor acting up below a certain temp) Then warming the coolant would help you more. Good thing about that magnet heater you are looking at, you could move it around and experiment to find the place that helps you start it better.
